Mixing oils?
MarsBar
PostPosted: 16:27 - 20 Sep 2002    Post subject: Mixing oils? Reply with quote
What are the facts here? I always try to use the same 100% fully synth 2-stroke oil every time I have to fill her up. That Motul Green smelly stuff. However, is it ok to mix other good makes of 100% fully synth oils together. And is it that if you mix fully synth with semi synth the oil will curdle?
Guest
PostPosted: 17:27 - 20 Sep 2002    Post subject: Reply with quote
i always use Silkolene pro 2 racing stuff 12quid a litre, damn good,bt as it was mixed with the remainder of the regular fully synth stuff fromwhen i brought the bike i found it doesnt really mix, as the better stuff sinks , then once tat gets used you notice it going back on to the lesser stuff, so i would say it doesnt really matter to much but you want to really gte rid of the lesser oil and only use the one type at a time.
andrew
Mister Road Rage
PostPosted: 21:29 - 21 Sep 2002    Post subject: Reply with quote
I wouldnt think it would cause any damage to the bike, well ive mixed fully synth and semi-synth before without problems. It wont cause any problems if you mix 2 different makes of fully synth either.
NSRboi
PostPosted: 14:26 - 24 Sep 2002    Post subject: Oil Reply with quote
The dealer had the Honda standard 2 stroke oil in my bike, I allowed it to run down then added Silkolene Comp 2. As the guy said in the previous post, it is marvellous stuff. Tho I bought mine for £9.50.
The Honda engineer said either Siloklene Comp 2 or Castrol TTS is the best for the NSR.
I had no problems with mixing, and now its running on the silkolene Comp 2 its 100%, and my spark is so much cleaner during servicing its unreal.
Never underestimate the healing powers of custard.
Get in touch with yourself by touching yourself. If anyone is watching, stop touching yourself.
The last post was made 21 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.27 - MySQL Queries: 17 - Page Size: 39.56 Kb
