cantona |
cantona Guest
Demonic69 |
Demonic69 The Pink Rhino
G |
G The Voice of Reason
Doddmaster |
Doddmaster World Chat Champion
Demonic69 |
Stew |
Stew If it's good enough for top race teams...
Posted: 15:57 - 25 Sep 2002 Post subject: |
Well if its the same as the single sided swing arm on the Nc30, then all you have to do is loosen the pinch bolt at the back. Then you need to rotate the hub-type chain adjuster either using a c-spanner or a suitable drift and hammer/mallet to 'tap' it round. The hub doesnt have to rotate too much to tighten the chain though.
you may find that the hub is stiff to move though, try spraying some WD40 on it and leave for half an hour before you attempt to rotate it.
Of course it may be totally different to the NC30, in which case all the above will mean nothing to you ____________________ "Unlike public school you don't need to have your arse up and your head down to go a long way...." |
The last post was made 21 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
