flat battery cause of hard starting?
hazza
PostPosted: 18:03 - 02 Sep 2007    Post subject: flat battery cause of hard starting? Reply with quote
not as stupid as i sound i hope, does my rxs 100 need a decent battery to start or is it bypassed straight to the coil?
basically after being layed up for almost a year the battery is flat, it takes alot of kicking to get it into life but once theres a little bit of power in the battery its fine (the dash lights come on when the ignition is turned on)
Lanny
PostPosted: 18:12 - 02 Sep 2007    Post subject: Reply with quote
I`ve got an RXS100 that I don`t use, so the battery was tatered
It played havoc with the lights and the indicators
I put a new battery on and everything was happy again
The Bloke from Stoke
Timmeh
PostPosted: 20:10 - 02 Sep 2007    Post subject: Re: flat battery cause of hard starting? Reply with quote
Nope. The battery forms part of the circuit. When you kick it over the generator spins and sends a tiny bit of current into the battery. At the same time the ignition electronics, coil, and CDI take power out of the battery to do their thing and make a spark.
The best way to check if a battery is working is to take it off the bike and to put it onto a trickle charger. If, after a few hours, the battery gets hot, then it's mullered.
Do this in a ventilated area because the battery might give off tons of hydrogen, which is very explosive.
hazza
PostPosted: 20:35 - 02 Sep 2007    Post subject: Reply with quote
so does a battery in poor conditionmake starting very difficult?
thanks for any replies
Timmeh
PostPosted: 20:38 - 02 Sep 2007    Post subject: Reply with quote
well yeah. If the battery's in shit state then the circuit's continuity is broken. You always need a tiny bit of charge to get it to start. Sometimes all the current drains of it and the lead plates get attacked by the acid. This is called a deep discharge.
It would be near-on impossible to start, because the coil/cdi would be trying to take more current out than what you were putting it in by using the kickstart.
hazza
PostPosted: 22:17 - 02 Sep 2007    Post subject: Reply with quote
cheers mate, i wa sjust curious because ive just done a full rebuild on it and thought something may still be wrong!
having previously owned to OLD mopeds which dont require the battery to start i was interested to see if this was the same, being 6 volt system and all.
cheers Thumbs Up
The last post was made 19 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 14 - Page Size: 53.54 Kb
