| c-m |
 c-m World Chat Champion
| b-f-c |
 b-f-c Traffic Copper
| c-m |
| lukamon |
 lukamon World Chat Champion
| c-m |
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 15:48 - 28 Sep 2007 Post subject: |
| c-m wrote: | That's fine, i'll buy all the parts needed and find a mechanic to fit it all. At the time he may as well do the fork seals and tyre valves too. |
Right, You have your shock absorber, which has an 'eye' that a bolt passes through to attach it to the bike
In that hole you will have a cylindical, hollow bearing called a needle roller bearing
https://www.globalspec.com/NpaPics/40/525_061420041448_ExhibitPic.jpg
Inside that bearing where the rollers are (You could put your finger inside it and twist, and the rollers would 'roll' and your finger would move round with no resistance) is a thick hollow tube
(The top left most item in this picture)
https://www.dewsproducts.com/Products/Bearing.jpg
In between the bearing and bush is a layer of grease, the main BOLT then passes through the hollow bit of the BUSH to attach it to the bike, this enables the joint to a) be securely fixed and b) rotate when the suspension is compressed.
Usually it's the bearings that need replacing, bushes sometimes get corroded and need repairing.
You don't need OEM bearings, take the old ones to a bearing factor and he will find you some new ones... "TOYO" are a good bearing manufacturer and there are a few others.
If you are lucky, the bearing serial will be on teh side of the needle roller.
You can get the new bearings pushed in by an engineering firm for pennies or you could construct a drawbolt assembly to get the new bearings in . |
| c-m |
| veeeffarr |
| Kickstart |
 Kickstart The Oracle
The last post was made 18 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
