 ttr Crazy Courier
 Posted: 18:45 - 01 Oct 2007 Post subject: New GS125 problem! Starter motor? |
Right! Sorted out the previous bolt woes, and wired in the new headlamp today, thankfully that worked without any complaint, so woot. The ticker for the indies doesn't seem to be working, but could that be because there's only one indicator wired in at the moment?
However, this is the more serious problem at the moment;
Earlier it was starting without complaint, now however, when I push the electric start button, the starter motor does its thing for a few seconds, then a sort of clunky-thud noise can be heard, and nothing happens.
The fuel tap is not set to off, this time!
Anyone got any thoughts?
[edit]
Right, just went down to the garage to try again on a whim, and it worked this time.
The question now is, why wouldn't it have worked before? Is this a problem I should be worried about, or is there some really simple answer? Is it likely to crop up again?
Cheers in advance! ____________________ GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550 |
 ttr Crazy Courier
 timjim Trackday Trickster
 Posted: 15:40 - 07 Oct 2007 Post subject: clunk |
Have you tried jump starting the bike,just to rule out a flat battery??  |
 ttr Crazy Courier
 Paddy Blake World Chat Champion
