Ste |
Ste Not Work Safe
Posted: 00:58 - 07 Nov 2002 Post subject: Odd Indicator Problem |
Ok, now this is not bull shit, as G, Luke and Craig have all seen it.
I have nice mini indicators fitted to my bike, and the flasher unit has also been changed. I think it did it before, with the brick indicators on. When i rev the engine, it flashes faster, and faster, till its almost constant. What could cause this, and how could i fix it?
Its really odd, and it might well be illegal, and i dont want it to happen in my test!
thanks |
Wingchunal |
Wingchunal World Chat Champion
drunkstudent |
drunkstudent Nova Slayer
Ste |
Ste Not Work Safe
zaknafien |
zaknafien
Posted: 06:48 - 07 Nov 2002 Post subject: |
Tin wont mind, i blame everything bad that happens to me on him. usually his fault ____________________ 02 Firestorm. |
Kickstart |
Kickstart The Oracle
Posted: 09:42 - 07 Nov 2002 Post subject: |
The regualtor / rectifier unit takes the AC voltage from the alternator and converts it to DC voltage of about 14 volts. Put a voltmeter over the battery, and it should be around (just under) 13V, rising to 14~14.5 with the engine running with some revs on.
To be honest I doubt this is the problem as when you rev the engine the indicators are fine. Sounds more like low battery power to me. You dont have a higher wattage headlight bulb in do you? If so try turning the headlight off and see if that fixes the problem. If the battery is marginal then the headlight drain will be noticable
Ste |
Ste Not Work Safe
moonym20 |
moonym20 Could Be A Chat Bot
Ste |
Ste Not Work Safe
Posted: 18:53 - 09 Nov 2002 Post subject: |
Nope, lights off doesnt help
It has the standard bulbs in there etc etc
And the Flasher unit is right? I think (TiN?!)
Will they let me do my test on thursday with it like this? ie, not being roadworthy or some other shit |
bikerboy1 |
bikerboy1 Trackday Trickster
Kickstart |
Ste |
Ste Not Work Safe
Posted: 00:10 - 10 Nov 2002 Post subject: |
Battery is fully charged, or at least the indicators were still doing it after it was fully charged, and then volt checked.
I will checkout the indicator relay tomorrow.
What do people think they will say on my test if they notice it?? |
Kickstart |
Posted: 12:25 - 10 Nov 2002 Post subject: |
Well, keep the revs to sensible levels so it isnt obvious. Also remember that the test has to take account of bikes with 6 volt electrics where the indicator speeds tend to be very slow at idle.
Rereading your original post you say the indicators get faster until they are almost constant. Sorry I read this as being that at high revs they are OK (sort of flash at a constant rate). If you mean (as I think you do) that they are on almost constantly then it does sound like a regulator / rectifier problem so check out the voltage over the battery as the revs go up
kev |
kev I Hump Things
The last post was made 21 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
