Good Idea ? |
no |
72% |
[ 13 ] |
yes |
27% |
[ 5 ] |
Total Votes : 18 |
jaz |
jaz Guest
Posted: 17:17 - 07 Nov 2002 Post subject: Nitrous on a 125?! |
Hi folks.
from the heading... the first thing id think is : dont be so f*ck*n crazy!
so when a friend of a friend said to the friend inbetween(ya with me?) that he was sellin his nitro injection kit as hes jus bought an r1 and was offerin it to me for £200, to put on my NSR125r,naturally i thought id better get some guidence!
so:
a) will it work?
b) will it burn the hell outa my bike
c) is 200 for a 2nd hand kit ok? ive no idea.
d) wot r the penalties for a 125 with 32 plus an Xtra 80bhp comin outa the can!?!
e)how much 4 sum new cans of gas(its one with 2 cylinders rather'n one, for ease of concealment...i like it )
anyone with some input, greatly appreciated. ta
j@Z |
Robson |
Robson Scooby Slapper
Posted: 17:30 - 07 Nov 2002 Post subject: |
1st off mate you will never manage to add 50hp to a 125 ive looked into this myself jetting is what to worry about as n02 add loads of oxgen to the fuel/air mix if its not spot o you'll blow a great big hole in your piston you could add 5hp extra without a problem, £200 is a good deal mate but idealy you need a pro to fit it correctly and get it running sweet basically its possible alright mate check out www.rdlccrazy.com hes modded a RD125 to accept nitrous and she did do 125mph so thats the best place i know of to source info on this kinda thing
Nitrous wont destroy your bike but improper fitting will mate and i would never add anymore than 5hp - 10hp to a 125 as you will blow your bike up the little 125 wasnt meant for 45hp+ the crank wouldnt survive anyway
Hope this helps mate ____________________ Cheers
Paul (Robson)
Kris |
Kris World Chat Champion
Posted: 17:50 - 07 Nov 2002 Post subject: |
I say go for it mate
FFS if everyone was sensible It'd be boring plus, if you had a 125mph NSR you'd get some serious attention at bike meets |
Ste |
Ste Not Work Safe
Posted: 17:59 - 07 Nov 2002 Post subject: |
There is another thread about this somewhere, but i cant be bothered to search for it!
If it does work, i would worry about the engine life, but what the fuck
let us know how it goes |
Scotty |
Scotty Scooter Boi
Ste |
Ste Not Work Safe
Posted: 18:02 - 07 Nov 2002 Post subject: |
and then there will be the task of insuring it!
although as G said in the other thread, you might well be dead, so i wouldnt worry about it |
Kris |
Posted: 18:05 - 07 Nov 2002 Post subject: |
If I remember rightly, the angle of the cylinder on the NSR means that if the engine did blow the piston is aimed at your nads
....something to think about when you're flat out doing 125mph on a 125 at 12000rpm |
tanner18 |
tanner18 Traffic Copper
tanner18 |
Kickstart |
Kickstart The Oracle
Posted: 22:16 - 07 Nov 2002 Post subject: |
I would be tempted to go for it, but you havent got a hope in hell of getting an extra 80hp from the nitrous. Probably at best another 20hp. It will take alot of time to set up properly, and if you get it wrong it will blow the engine up.
However, at £200 it is fairly cheap and would be fun to add to a larger bike
Lots of things will need to change to make the best of the nitrous, such as ignition timing, fueling and gearing. Combined these will make the bike noticably slower when you are not using the nitrous
Robby |
Robby Dirty Old Man
Robson |
Posted: 09:27 - 08 Nov 2002 Post subject: |
I myself would say go for it mate just get a pro to fit it as i said before nitrous wont blow your bike up (well unless your adding and extra 30hp through it) but impropper fittment will so thats worth taking into account you should be able to get away with 10hp (you can buy jets that meter the n02 flow ie you can get 5hp jets this will also make your tank last longer which can only be a good thing eh) but believe me 10hp extra on a 125 is one kickin the pants extra it will go like sh*t of a stick mate but you idealy need a progressive controller as you dont want an extra 10hp comin in all at once as it would probably make your bike flip unless you never let her rip until you were doin a high speed anyway, im sure the controllers do cost a bit aswell mate. have a look at
https://www.noswizard.com/
you'll find all the info you need mate you can also ask them questions about the systems and controllers they sell via email
Paul (Robson) |
Robson |
j@Z |
j@Z Guest
Posted: 16:01 - 08 Nov 2002 Post subject: oh |
see, i had a pretty good idea of the response...but if one out of ten says it might work then bugger it..im gonna try
It will be fitted by a pro of course.. im a rider not a mechanic...
so ill go with the 10hp jets(or maybe 5 to start) and probabally forget the prog controll unit, jus not kick the switch till im steamin anyway...
i cant afford the prog unit...but then again i cant afford to fix a battered engine... well ill need a new job then ay
nos on an rs? they blow up after 7k anyway!! lol id never put one on them...
i need the bike re-jetted anyway so may aswell do the lot when we put thee kit on.
Thanks all for the input. i will be (extremely) carefull with it(if i do indeed go for it).. but if u see an all black blur doin 120 and it sounds like a torchered pig... its me, wave!
oh.. and just in case...ill wear a box if im gonna be canin the Nitro!
Ill let y'all know how it goes.
thanx
j@Z |
Robson |
Posted: 16:22 - 08 Nov 2002 Post subject: |
Thats the one mate go for it let us all know how you get on with it ____________________ Cheers
Paul (Robson) |
Keith |
Keith Guest
kev |
kev I Hump Things
Ste |
Ste Not Work Safe
Posted: 12:06 - 10 Nov 2002 Post subject: |
Duke: order from https://www.noswizard.com/
Get the 300bhp one
Now that would be fast!!!!!!!!!!! |
kev |
kev I Hump Things
Ste |
Ste Not Work Safe
kev |
kev I Hump Things
stevo |
stevo Two Stroke Sniffer
Posted: 12:31 - 10 Nov 2002 Post subject: |
I personally wouldent want Nitrous on a 125cc. I dont really like nitrous anyhow. Its got too many limitations. I mean you can only use it for short bursts, unless you want to blow the motor up or empty the bottle in 1min. It usually can only be used at full throttle in the higher gears, and cant be kept on during gear changes or a full run through the box. Its expensive, and then theres problems with locating the bottle, and all the wiring, and solenoids required etc. I think its more of a risk on a 2stroke as you cant afford to let it run weak even for a few seconds. And as said b4 your bottom end isnt gonna take kindly to another 10bhp in the long term. Having said all that there are a few people who have used nitrous with some sucess on small 100-180cc 2stroke scooters. The SCCC peugeot speedfight has had a Nitrous system developed for it, (system by NOS) and it seems to work well after a few teething troubles. its taken a 125cc speedfight from 12bhp to 24bhp, and it now does 16sec 1/4mile@80ish. For the street its just too much hassle and expense on a 125. If you want other ways to stress your bottom end and add power to an NSR then i think it would be a far better idea to go for a 160/180cc big bore kit, and a bigger carb etc, as youd probably get a bit more power and torque, which would be available all the time, and not just down a long straight.
The most powerful road going stroker (probably/definately) in the country (Mark Dents suzuki RGV575) doesnt have Nitrous fitted, and that makes 145bhp at the wheel!! So at the end of the day theres no substitute for ££££'s worth of race tuning and specially made components, along with hundreds of hours of work. ____________________ The Voices made me do it. |
kev |
kev I Hump Things
Mr Lucky |
Mr Lucky Spanner Monkey
Posted: 02:50 - 11 Nov 2002 Post subject: |
You will kill the bike unless you have it fitted professionally. It is as simple as that.
What kind of kit is it?
Do yourself a favour and spend the money you were going to chuck on the Nos to buy a big bore kit instead. Always there, cheap, effective and a lot of fun too... ____________________ https://www.labusas.org |
The last post was made 21 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
