moonym20 |
moonym20 Could Be A Chat Bot
Posted: 00:29 - 09 Nov 2002 Post subject: Chain Query |
Hello, it's prolly me being as thick as two shot planks but its still a query n that what this forum is for
i have an 01 NSR 125R with a bog standard O-Ring Chain its done 4,875 miles since April (when new)
ne hows before my Chain used to sag with use so i'd adjust the tension and everything is fine, i've done almost 500 miles since my last tension adjustment and the chain sags a bit but has enough play to hit the underside of the swing arm also when its on the paddock stand and i rotate the rear wheel its sounds more 'gritty' than usaual at the front sproket
just wonding if this is normal or somthing to pay attention to before its 5,000 mile service tomorrow (BTW i lube my chain with O-Ring safe lube about every 200miles or so)
thanks
Joe |
craigT19 |
craigT19 Jolly Green Giant
Posted: 00:49 - 09 Nov 2002 Post subject: .... |
sounds like you need to lube ya chain more regulally mate ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
Phoenix |
Phoenix Twisted Firestarter
Posted: 02:22 - 09 Nov 2002 Post subject: |
every 200miles should be fine, i usually do it when I think it needs it which can be anything from 130-200miles. Give it a clean, it's prolly got loads of dirt stuck to it, so get a rag and your cleaner of choice and wipe it all clean then lube it again.
If the chain can touch the swingarm then it needs adjusting, but it shouldnt be a problem unless you change gear really crap or have a habit of going up steep hills in 4th gear then chaning straight down to 1st and jamming the throttle open check the chain for tightspots and check the teeth on the sprockets, see if theyre wearing badly, if so maybe time for a new C&S |
moonym20 |
Posted: 14:26 - 09 Nov 2002 Post subject: |
thanks for the feedback, the chains fine, there was a little grit around the front sproket from all the crap weather
my front brake is very spongey i need to pul the lever right back so its basically touching the bars, i went back and the mechanic just said it's becuase everything hase been lubed up and they will go stiff again as i use them more (i still have my old pads in) just wondering if this was true or not cos i only needed to tap the lever to get full breaking power now im having to pull it right back |
retrofly |
retrofly World Chat Champion
Posted: 15:11 - 09 Nov 2002 Post subject: |
hi
yeah, sum times thr gritty sound could be the rear wheel bearings, i looked at mine the other day and they were covered in crap, just take the wheel off and they should just fall out
Luke ____________________ "The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly |
Ste |
Ste Not Work Safe
Posted: 18:53 - 09 Nov 2002 Post subject: |
I think i need to do my chain. 1600 miles so far |
Kickstart |
Kickstart The Oracle
The last post was made 21 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
