| Serendipity |
 Serendipity World Chat Champion
 Posted: 10:52 - 11 Nov 2007 Post subject: CBR600F – Oil in coolant |
Story so far –
* Coolant expansion tank overflows with oil/water mix porridge. (Almost a year ago)
* No contamination in oil, just oil getting into water.
* Suspect head gasket or oil pump failure.
* Paddy Blake from BCF suggests o-ring failure in oil cooler.
* Bike goes into storage for a year until this month when I finally start working on a fix.
* Bike starts on second push of button after standing for a year.
* Drain oil – all clear, no contamination.
* Drain coolant – all clear until the last bit – oil floats I guess – then a bit of porridge.
* Remove radiator and exhaust system and take off the oil cooler.
So here we have more porridge. This stuff came from the coolant hose to the bottom right of the picture.
https://i221.photobucket.com/albums/dd227/serendipity_uk/CBR600FR/IMGP4118a.jpg
The cooler dismantled: Oil passes through the radiator thing while the coolant flows around it inside the cooler housing. More porridge inside the cooler.
https://i221.photobucket.com/albums/dd227/serendipity_uk/CBR600FR/IMGP4121a.jpg
The o-rings where the radiator fits into the cooler body were indeed totally knackered. Both were hardened and misshapen. Slightly more concerning is a bit of pitting on the cooler radiator thing where the o-rings were sitting. Could this be the failure point? I guess the oil was being forced into the coolant at this point. (Thanks for the diagnosis Paddy)
https://i221.photobucket.com/albums/dd227/serendipity_uk/CBR600FR/IMGP4124a.jpg
Is it worth trying to fill the pitting with Araldite or epoxy putty? Or would it be safer to just buy a new part? New o-rings are already on order and I really don’t fancy having this fail again.
Cheers Simon ____________________ 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| Paddy Blake |
| Phil_P |
 Phil_P Trackday Trickster
| Serendipity |
 Posted: 15:29 - 11 Nov 2007 Post subject: |
Thanks for that. Can anyone recommend a good machine shop in the High Wycombe/South Bucks area?
As far as degreasing goes I would normally use isopropyl alcohol (IPA) and I’ve got a little butane/propane torch. However I will go down the more professional route first.
Cheers.  ____________________ 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
 Posted: 15:40 - 11 Nov 2007 Post subject: |
I would glue/tape a couple of sheets of 280-grit wet & dry to a flat surface and lap those marks out using WD40 as a lubricant. Should take less than 10 minutes. ____________________ a.k.a 'Geri'
| Paddy Blake |
The last post was made 18 years, 82 days ago. Instead of replying here, would creating a new thread be more useful? |
