Project dr400
kat250
PostPosted: 20:36 - 03 Feb 2008    Post subject: Project dr400 Reply with quote
Well i managed to pick up a shed of a dr400 for next to no money off a mate of my dads. The idea is to build a work horse bike on the cheap. and get it back together within the month.
https://i128.photobucket.com/albums/p183/babykat250/P1270001.jpg
https://i128.photobucket.com/albums/p183/babykat250/P1270002.jpg
My dad also had an sp370/dr400/ts125 hybrid thing sitting about so dug that out.
https://i128.photobucket.com/albums/p183/babykat250/P1270004.jpg
https://i128.photobucket.com/albums/p183/babykat250/P1270005.jpg
Got straight into dissmanteling it and discovering all the lovely snapped bolts seized and fucked bearings and lots of lovely things like the mouse nest in the airbox still being inhabited Laughing .
https://i128.photobucket.com/albums/p183/babykat250/P1270007.jpg
https://i128.photobucket.com/albums/p183/babykat250/P1270008.jpg
https://i128.photobucket.com/albums/p183/babykat250/P1270011.jpg
Got everything out and then was left with the swingingarm berings being seized to high mighty and took alot of persuaeding to get out
https://i128.photobucket.com/albums/p183/babykat250/P1280014.jpg
Got it all stripped and ready to start any welding painting and reassembely. I intend on fitting the ts125 front end which has a disk brake and should be a vast improvement on the drum.
https://i128.photobucket.com/albums/p183/babykat250/P1280015.jpg
in the famous word of jimmy pop "would you F*ck me for blow"
In the words of banditshigh "would you blow me to f*ck"
garth
PostPosted: 13:43 - 04 Feb 2008    Post subject: Reply with quote
Oooh I've had a play on one of them. Good fun to kickstart. Neutral
kat250
PostPosted: 13:52 - 04 Feb 2008    Post subject: Reply with quote
Were you using the decompression setup Wink
garth
PostPosted: 14:17 - 04 Feb 2008    Post subject: Reply with quote
Embarassed
Maybe
kat250
PostPosted: 14:39 - 04 Feb 2008    Post subject: Reply with quote
I know the feeling the previous owner had it off so kicking it over was a nightmare probably didnt help the airbox had a mouse nest in it Laughing .
On another note i have another 3 spare engines for this bike one that is built to sp370 spec with new piston, barrel and rings and another with a top end other one just need a barrel Laughing .
kat250
PostPosted: 17:43 - 15 Feb 2008    Post subject: Reply with quote
Quick update frame stripped and bits welded as right hand foot peg mount had managed to rip out the frame mounting points. Found some lovely chunk of metal in the dr engine, so checked the spare sp engine it has a bent selector shaft Rolling Eyes . So gonna rebuild the dr engine its also low on compression so a good chance to get it in working order. Also had a fer problems with fitting the ts125 front end so had to hack a spare dr yoke for the stem and swap stems. Ill get photos up tommorow
The last post was made 18 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.17 - MySQL Queries: 14 - Page Size: 50.21 Kb
