European expedition June 2008
c-m
PostPosted: 13:32 - 26 Nov 2007    Post subject: European expedition June 2008 Reply with quote
Hi,
I am still on my CBT and ride an RD125lc when its working Wink
A friend and I are planning on traveling around Europe for one month next summer (June). We will both be taking our Standard or DAS in the next 3 months and were wondering on type of bike to get for this adventure.
I know this has been asked before but i'm looking for some more specific answers.
I will have a budget of around £1000 for a second hand bike and want something that will be able to carry all my gear and potentially a pillion (for some of the way). It needs to be cheap and easily serviced with parts common around mid/eastern europe.
Ideally i would a fairing for some weather protection
What would your recommend?
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
Itchy
PostPosted: 14:01 - 26 Nov 2007    Post subject: Reply with quote
Get a courier bike, when I say this I mean a bike a courier'd use but not one that has been couriered on,
NTV/GT550/750/CX500/CB500/CB1/Bros/XJ900
+ aftermarket fairing, (NTVs can be had for oh £300 these days just get one OUTSIDE the M25 infact all of the above bikes get one outside the M25).
utterly indestructable in the hands of dispatch riders , and thus no real need to have something that has parts avalible in those erm parts, they know how to fix that stuff too ya know,
the NTV/GT/CX have the advantage of shaft drive also = less chain adjusting , though still get a scot oiler.
All of them cept the CB1 and Bros have big tanks (the XJ has a big tank but is terribly thirsty), can carry luggage and are cheap for parts and deadly common too.
Maybe also consider a pre 98 CBR600F (yeah I know you can get CBR600F4 on for about £1500ish) , or ZX6R mid 90s , for some sporty performance , (I went touring on a CBR600FX carried 110 litres of luggage fine and would have carried a passenger fine and still went over 150mph) but bad on fuel if you are like me.
c-m
PostPosted: 12:45 - 27 Nov 2007    Post subject: Reply with quote
seen a lot of people talk about the vfr400 and it being a very good all rounder.
Itchy
PostPosted: 13:36 - 27 Nov 2007    Post subject: Reply with quote
The VRF400 is a good touring bike, Maurice swears on his 80K one, CRM250 , Matt have toured on theirs:
It has problems though:
> 2 up its not very good
> 2 up + luggage its worse
> VFR400s run HOT , even if you clean up both radiators (be careful as the fins bend easy) by design , Maurice in 2004 went to Spain and it overheat badly , even worse in cities this added to the hot climate = v bad , my CBR went left in the hot sun the fan was on almost all the time and firing it up it started (the temp) on the middle.
> No cush drive, (rubbers between the sproket and wheel) which means they are hard on Chains and Sprokets, and need a fair bit of adjustment VFRs eat those things alive
> 18 Inch rear tyre, most common types are 17 inchers which mean you break it or wear it out many places may not have them in stock
> Its seating position is very racy, its ok for a couple hours ride out but when you start racking up the distance you may need to be surgically removed from one al la DM when she went to Cadiz on hers (and DM is 5.1 and tiny).
c-m
PostPosted: 22:30 - 27 Nov 2007    Post subject: Reply with quote
Fair enough.
I'm coming from old 2 strokers like Rd125 KH125 etc.. so anythiing will feel like a massive power leap.
2up (obviously i've practice first) would only be some of the time.
I'm happy to look at 400-600cc don't want to go too mental after first passing my test.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 22:52 - 27 Nov 2007    Post subject: Reply with quote
VFR400's aren't great with pillions without luggage, I wouldn't look forward to trying it with luggage tbh.
Otherwise can be quite good for a sporty Europe tour!
Itchy
PostPosted: 23:01 - 27 Nov 2007    Post subject: Reply with quote
Honda Hornet? , the older F one which had a bikini fairing on top, for wind protection, handles pretty good enough bhp to handle luggage and pillion (though in some discomfort) and suspension able to handle it too,
though has an appauling tank range via a tiny tank and a endurance tank bodge will take up valuable space.
Perhaps you should credit card tour? , or just bring 2 sets of clothes, wash one wear the other , infact on my tour I wore only 3 T shirts out of the 6 I bought 2 pairs of socks and 2 pairs of jeans and I bought way too much
c-m
PostPosted: 12:41 - 28 Nov 2007    Post subject: Reply with quote
Can you get a lower fairing at all for the CB500s?
Also what about the GPZ500 and GS500F for touring?
Another question is how do these compare performance wise to something like an NC30?
I have noticed that most of the bikes you listed actually had less BHP than the NC30, yet should be able to handle more wieght?
Itchy
PostPosted: 13:51 - 28 Nov 2007    Post subject: Reply with quote
AFAIK the CB500 came in 3 flavours the naked one and the S one which had a nice fitting top fairing,
CB500 is about 55bhp
GPX500 about 55-60bhp
GS500F , just a GS500E with a fairing (££££) worse for weight,
The big difference is the suspension as the '30 has much more adjustable suspension the others don't , all the parrallel twins you speak of also are good along the low and middle power band while the NC generates its power zone arouind the 7000RPM+ zone.
Since you have to select gear carefully anyway you'll get annoyed probably having to constantly change gears.
EDIT performance wise how? ,
power isn't everything, they will take corners worse than the '30 however they maybe even on acceleration , while the 500s and rat 600s don't rev as high the extra 100 or so CC gives a fair bit more torque. Braking late into corners the '30 is better too due to lower weight better suspension and double front discs though GPZs do come double front discs,
frame issues you'll only notice weight you aren't a MotoGP rider (nor am I) so its barely notivable.
remember Man not machine , down Italy/France I met riders on rat bikes CB500s GS500s , falling apart CB250s , who knew the roads well , and could take them at insane speeds.
quik_d
PostPosted: 14:54 - 28 Nov 2007    Post subject: Reply with quote
unless i've missed it nobody has mentioned the 600 bandit yet. I picked up a T reg one last august for £750, and it took me round Europe for a month fully loaded no problem. I regularly ride 2up now and its not problem with that either
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
Itchy
PostPosted: 21:22 - 28 Nov 2007    Post subject: Reply with quote
not seen bandits go for <£1000 tbh , (that is in good nick).
quik_d
PostPosted: 13:23 - 06 Dec 2007    Post subject: Reply with quote
I know what you mean, i think i was just very lucky with my my 99' bandit, the guy was loaded and he had a start bid of £750 and i just said will he take it.
It does have a few scratches down the rear right panel where he dropped it after washing it once, and when i got it the collector pipe had rotted and was blowing a wee bit, but a local welder filled that hole for me and i have now got a full stainless system.
Apart from that its in good nick.
Method
PostPosted: 10:23 - 07 Dec 2007    Post subject: Reply with quote
GS500
- Rediculously easy to work on should you break down
- Parts are common as 1p coins
- Parts are as cheap as 1p coins
- Tyre is an easy size
- Bullet proof engine
- Will happily carry all the luggage you can throw at it
- Will take a pillion at the same time
- Actually handles better with a bit of weight on it
- Tank range is great, can get 150miles to a tank if your steady
- You feel like a hero once you complete you trip on one
- Can be picked up for about £500 now
- Aftermarket full fairings are readily available for them and give amazing amounts of protection
- Riding position is great
- A quick post on here before you go will see large amounts of people with parts that you may need, and lots of advice
Thumbs Up Smile
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
jimbothe
PostPosted: 23:17 - 09 Dec 2007    Post subject: Reply with quote
I didnt see any mention of bhp restriction.
If not why not go big air cooled like the FJ1200. This bike wrote the book on long distance travelling and a nice one can be bought for under a grand now.
If you cant get 140,000 + miles out of one you are doing something seriously wrong.
A cbr 600 will keep up with the acceleration of a FJ1200 so I wouldnt consider it too mental. Insurance companies love you as well as they are considered old hat and middle aged riders.
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
PostPosted: 06:43 - 10 Dec 2007    Post subject: Reply with quote
CX's and GT's are getting on abit now, I would avoid.
Itchy
PostPosted: 09:15 - 10 Dec 2007    Post subject: Reply with quote
CXs yes , but they were built and imported till '96 GT's were built up until 1999 0r 2000,
c-m
PostPosted: 09:23 - 10 Dec 2007    Post subject: Reply with quote
Saw GS500 close up last night, seemed nice, but looked particularly heavy.
I'm sure most of the bikes mentioned will be fine, its just a case of finding the one at the right price in the right condition.
Itchy
PostPosted: 09:26 - 10 Dec 2007    Post subject: Reply with quote
GS500 isn't actually very heavy , its about 180kilos dry, the lack of radiator, to discs and big fuel tank and sump as well as a complex zorst system mean its actually quite light but has a small tank, its also quite small to my eyes. (compared to the big NTV that is).
c-m
PostPosted: 13:04 - 10 Dec 2007    Post subject: Reply with quote
yeah did look like it had a short wheel base compared to the CBX750 and GPZ500
c-m
PostPosted: 22:53 - 03 Jan 2008    Post subject: Reply with quote
Only 6 or 7 months to go.
Most the GS, GPZ, CB, NTV etc.. hanven't been going for as cheap as I expected on ebay, though still nicely under £1k
Probably won't be carrying a pillion, what are the more sporty options for less than £1k?
c-m
PostPosted: 19:01 - 21 Jan 2008    Post subject: Reply with quote
Method wrote:
GS500
Thumbs Up Smile
Have read that the ER5 despite less horsepower is faster than both the GS and CB, but is worse for fuel economy 45mpg compared to 55mpg for the CB and 60mpg for the GS. Obviously it all adds up over a 6000mile journey.
I saw a CB in the flesh with a powerbronze after market fairing on and it looked disgusting. The fairing looked terrible and the bike itself looked very tall and clubsy, nothing at all like the GS which I think is now my prefered choice (unless I find a GPZ or CBR600F). Still keeping an eye out for a bandit though.
Anyway out of all the bikes i've mentioned do any of them have CUSH drive?
c-m
PostPosted: 18:07 - 14 Apr 2008    Post subject: Reply with quote
Thought I'd revive this thread now that June is fast approaching.
I passed my test as planned towards the start of the year.
At the time i was desperate for a bike so bought a 1996 GPZ500 with 23,000 miles and some service history for less than three quarter of a grand. Tyres are good, so are chain and sprockets. I recently carried out a valve clearance, fitted a loobman and will be syncing the carbs this weekend.
So far I've done around 1.5K miles on it including long trips form Norwich to Canterbury, London and back again, but to be honest I'm already pretty bored of it. Handling isn't great and screen/fairing is a bit rubbish at high speed
I've got around £1.3 to spend and not sure whether I should be looking at getting something else.
The last post was made 18 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 133.29 Kb
