changing g/box oil?
stirlinggaz
PostPosted: 19:40 - 26 Dec 2007    Post subject: changing g/box oil? Reply with quote
Hi,
i reckon its time to change gearbox oil,(aprilia rs125)
book says - SAE 75E - 90.
but cant see any in halfrauds, 'cept for car gearbox stuff, recommended for suby imprezas etc?
will any car oil do? ( as long as its for gearboxes & 75-90?)
stuff i seen was for L.s diffs?
anyone know if it will be ok to use?
what about the numbers - 75/90,
can i deviate slightly - ie - 70/80 0r 80/90? (im sure u know wot i mean)
or anyone know of a suitable alternative
tried rockoil lite before butwasnt sure about it so looking for a synthetic alternative.
cheers,
GAZ
salty21
PostPosted: 19:49 - 26 Dec 2007    Post subject: Reply with quote
this should be about right
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_263777_langId_-1_categoryId_77871
I had the same problem a while back and was advised by quite a few people to use this. i have had it in mine for about 5000miles and it runs fine Thumbs Up
cagiva gezzer
PostPosted: 19:50 - 26 Dec 2007    Post subject: Reply with quote
Any "light gear oil" is what you're after. You'd be hard pushed to justify getting fully synthetic oil for a stroker gearbox.
Failing to find 2T light gear oil, try some motorcycle 10/40 engine oil.
stirlinggaz
PostPosted: 04:08 - 27 Dec 2007    Post subject: Reply with quote
Hi,
found a supplier of silkolene comp lite.(& its synthetic)
which has been recommended by other rs owners.
& its only about £6 or £7.
one thing that confused me tho,
when you ask a garage or halfords etc, for 75w -90 gear oil,
they automatically presume its for a car or 4 wd?
as thats whats seemingly used in them?
so would it be the same stuff?
ie- as long as it says 75W-90.?
cheers,
GAZ
The last post was made 18 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.83 - MySQL Queries: 14 - Page Size: 41.04 Kb
