No brake light when applying the back brake
apple tango
PostPosted: 17:19 - 02 Jan 2008    Post subject: No brake light when applying the back brake Reply with quote
The other day i notcied that when i use the back brake, the light doesn't come on.
It comes on when i apply the front brake though.
Surely this isn't normal?
CBR125 -> Bandit GSF600 '99 -> SV650 02
Ichy
PostPosted: 17:27 - 02 Jan 2008    Post subject: Reply with quote
No its not normal.
Either the brake switch needs adjusting, obvious to see how to do it if you take a look at it, the spring connecting the switch to the pedal has come loose, or the switch or wiring is faulty.
Go for the easy stuff first and see if it works if you adjust it.
To test the switch short out the two wires going into it. Make sure the ignition is turned on.
dave49
PostPosted: 18:39 - 02 Jan 2008    Post subject: Re: No brake light when applying the back brake Reply with quote
Its obviously the brake switch.Try pulling the switch down manually to see if the light comes on.if it does your back brake or pedal needs adjusting.if it doesnt come on its probably the switch itself.
apple tango
PostPosted: 18:58 - 02 Jan 2008    Post subject: Reply with quote
Cheers i'll have a look
The last post was made 18 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.32 - MySQL Queries: 14 - Page Size: 39.75 Kb
