Can you flood a fuel injected bike?
craigs23
Mr Muscle
PostPosted: 14:14 - 05 Jan 2008    Post subject: Can you flood a fuel injected bike? Reply with quote
I tend to think it's not possible, but I'm attempting to get to the source of my recent R6 starting problem.
PostPosted: 14:24 - 05 Jan 2008    Post subject: Reply with quote
Yes you can flood a fuel injected engine. Normal way it happens is opening the throttle while cranking it over. Especially with the pretty crude fuel injection systems primarily mapped off throttle position used on many bikes.
craigs23
Mr Muscle
PostPosted: 16:24 - 05 Jan 2008    Post subject: Reply with quote
Hmmmm, so my recent problem https://www.bikechatforums.com/viewtopic.php?p=1674394#1674394 doesn't seem to be a likely flooding?
PostPosted: 17:32 - 05 Jan 2008    Post subject: Reply with quote
Not sure. You say the starter cranked over, but did the engine?
craigs23
Mr Muscle
PostPosted: 18:38 - 05 Jan 2008    Post subject: Reply with quote
I'm guessing it did, as the oil light went out (as normal) when I pushed the starter. Just trying to find out why it didn't start....
PostPosted: 19:01 - 05 Jan 2008    Post subject: Reply with quote
Most Yamahas use an oil level warning light rather than an oil pressure warning light. And as far as I have seen these illuminate while the engine is off and then go out when you press the starter button (ie, rather than when the engine is running). Had Yamahas that are not turning over in the slightest and the warning light goes out as soon as you press the button.
craigs23
Mr Muscle
PostPosted: 19:03 - 05 Jan 2008    Post subject: Reply with quote
Hmmm, similar light on the R6 dash I think.
Any ideas to the likely cause?
PostPosted: 19:09 - 05 Jan 2008    Post subject: Reply with quote
If not cranking over at all then possibly something simple like the starter relay or side stand cutoff switch.
craigs23
Mr Muscle
PostPosted: 19:31 - 05 Jan 2008    Post subject: Reply with quote
If the starter relay is one of the small items under the saddle (similar in looks to an indicator relay), I did note that it lightly 'clicked' in to operation (as normal, I presume?) each time the bike was switched on and off (barely audibly over the whine of the fuel injection system, etc).
I checked the sidestand switch today, seemed to be functioning as it should....
What I don't understand is to why the bike's now working as normally as it ever should. There was no loud bang of unburnt fuel when it started, it fast idled as normal and returned to its usual smooth idle once warmed up.
Confused
Noxious89123
PostPosted: 20:21 - 05 Jan 2008    Post subject: Reply with quote
Damp electrics??
NSR-Rulez
PostPosted: 20:41 - 05 Jan 2008    Post subject: Reply with quote
Well you learn something new everyday i didnt think you could flood one, but i didnt know if you could or not.
craig your bikes are kept inside arent they? which would put damp electrics out i would have thought.
Past: 1985 Suzuki GS 125 + 2002 Honda NSR 125 R-2 + Ford Fusion
Present: Honda CBR 600 RR-5 + Suzuki SV650S-K4 + Mitsubishi FTO GPX
PostPosted: 21:31 - 05 Jan 2008    Post subject: Reply with quote
It would only click when the starter button was pressed, and would normally be drowned out by the noise of the starter motor.
No "bang" suggests that (if it was cranking over before) then it wasn't getting any fuel. No fuel and no sparks suggests it isn't getting a signal for the crank position.
Pete.
PostPosted: 12:09 - 06 Jan 2008    Post subject: Reply with quote
Many bikes inject a long squirt of fuel when you cycle the ignition/run switch in preparation for starting the engine. If you do this too many times in a row you can flood the engine.
a.k.a 'Geri'
craigs23
Mr Muscle
PostPosted: 17:01 - 06 Jan 2008    Post subject: Reply with quote
Hmmm. Odd. Bike seems fine now, maybe it did, somehow, flood. It was very similar symptons.
I added a bit of injector cleaner to the tank, just in case that was the problem. Because, at the moment, given the coincidence of the previous night's fill up, it's the only thing I can think of (not sure how long the bike was sitting in the showroom).
wikiwiki
PostPosted: 17:45 - 06 Jan 2008    Post subject: Reply with quote
I had a yamaha, once,Rolling Eyes Didn't amuse me at all after one long ride it decided not to turn over on the return journey, push started it and off it went.
Then the next day electric starter was o.k, then next day didn't work.
I hate intermittent faults Evil or Very Mad
I took a morning to have a look only to find the starter motor feed from the relay, corroded (was right behind the front wheel so it could catch all the water and crap) but more of a problem, loose, My guess is it wasn't very tight to start with and the long run made it rattle off.
There was a click from the relay but no starter motor turning.
If your bike has, for no reason just cured itself and these were your symptoms, check the starter motor feed.
craigs23
Mr Muscle
PostPosted: 17:56 - 06 Jan 2008    Post subject: Reply with quote
As I mentioned earlier, the starter motor seemed to be working fine throughout. The bike just didn't seem to fire (I was going to check the plugs after my last couple of attempts to bump start the bike, but didn't need to in the end).
I'm just concerned that the bike failed to start through some unknown reason. If or when it'll happen again isn't something I'm looking forward to. I'm going to look into breakdown recovery services, just in case.
If it continues to do it, I think the bike's still under warranty (which I don't fancy invalidating) so I'll get the garage to take a look at it. Or I'll consider exchanging it for something more reliable.
The last post was made 18 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 94.3 Kb
