Barrel rusty after rebore
darkangel
PostPosted: 13:11 - 23 Jan 2008    Post subject: Barrel rusty after rebore Reply with quote
Hey this isn't actually a problem but a while ago i had a rebore done and when i got home and cleaned the barel out with wd40 then wiped it down with water and dried it.
I left it for a while to make sure it was all dry before i put it back in the engine, but when i came to put it in i found a thin layer of rust inside the barrel!
I tried to wipe it down again with some more wd40 but couldn't get it off.
Anyway it has been in my engine now for the past 3k miles and hasn't caused any problems, just wondering if anyone else has experienced this.
Walloper
PostPosted: 14:30 - 23 Jan 2008    Post subject: Reply with quote
I had to dig a 6 cyl. diesel engine cylinder head out of 12" of snow one morning.
I wiped off the snow. Checked the head was OK and clashed the engine together.
It's been running fine ever since.
Anyone else?
PostPosted: 17:48 - 23 Jan 2008    Post subject: Reply with quote
Well, I would have either left the WD40 on it or wiped round the bore with some light oil. Why on earth did you decide to wipe it with water?
Being very light rust, it probably just acted like honing marks and seated the rings nicely.
If the same had happened to me, I would have wiped it down with an oily rag, run the honing tool through it then rinsed it in solvent and oiled it again before fitting.
ZRX61
Victor Meldrew
PostPosted: 20:10 - 23 Jan 2008    Post subject: Reply with quote
Just a heads up: after I bore cylinders I clean em up & then wipe down the bores with ATF to protect em.
Walloper
PostPosted: 21:03 - 23 Jan 2008    Post subject: Reply with quote
Is it OK to clean them down then wipe them up? Razz
panpan
PostPosted: 23:21 - 23 Jan 2008    Post subject: Reply with quote
How long did you leave it for?
darkangel
PostPosted: 00:43 - 24 Jan 2008    Post subject: Reply with quote
a few hours, there may still have been some moisture inside but not in any of the important bits like inside the barrel, i cleaned that thoroughly.
I never would have believed rust could form that quick, it literally appeared in seconds, it did not effect the bore in any way other then making it look a bit discoloured.
It was a bit stupid wiping it down with water, but i never expected a little bit of water to do that so quickly.
Odie
PostPosted: 08:43 - 24 Jan 2008    Post subject: Reply with quote
NO!
This bike will blow up in 25 miles!
Lol Mr. Green Mr. Green Mr. Green Thumbs Up Thumbs Up
Only joking, should be ok, but why wash it with water?
hazza
PostPosted: 11:24 - 24 Jan 2008    Post subject: Reply with quote
why water?
thats what i asked my tit of a father when i got home to find him submerging my petrol tank with the filler cap removed in a bucket of water washing it ready for paint. the inside of my tank is mank now, and like this, it formed within minutes.
V2
PostPosted: 12:56 - 24 Jan 2008    Post subject: Reply with quote
NO NO NO always clean them UP then wipe them DOWN.
The last post was made 18 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.86 - MySQL Queries: 14 - Page Size: 63.63 Kb
