Reccomend me a chain lube...
Scouse
PostPosted: 23:04 - 11 Feb 2008    Post subject: Reccomend me a chain lube... Reply with quote
I recently changed from Rockoil chain wax to Castrol chain wax. Now the Rock oil stuff was good but didn't half make a mess of the chain (crud wise). Then there's the Castrol shit, not only does it fling all over the show in a huuuuuge way that it took hours to clean it all off the bike, but the chain has stretched so much since using it that it is untrue. Also since using the Castrol stuff I can always feel knocks in the chain and it still constantly seems rusty even when using it after every ride.
So can anyone reccomend one that doesn't fling but does a good job of taking care of the chain?
PostPosted: 23:07 - 11 Feb 2008    Post subject: Reply with quote
I've found castrol stuff to be pretty good.
Using Wurth at the moment, it's ok.....
Mottrax HP lube it very good too. Wink
Adam80UK
PostPosted: 23:14 - 11 Feb 2008    Post subject: Reply with quote
Gotta be Wurth Dry Lube
Current: '07 Suzuki SV1000 & '07 Honda SH300i (again).
Previously owned: '08 Yamaha R1, '10 Kawasaki Z1000, '07 Honda SH300i, '04 Suzuki SV1000S, '11 Honda CB1000R, '09 Kawasaki ZX-10R, '08 Aprilia Tuono 1000R, '07 Triumph Daytona 675, '95 Honda CBR600F.
MarkJ
PostPosted: 23:19 - 11 Feb 2008    Post subject: Reply with quote
I just use normal car engine oil and my chain has lasted a good 20K miles. I also hear chainsaw oil is good stuff too.
PostPosted: 23:20 - 11 Feb 2008    Post subject: Reply with quote
I know Craig23 uses chainsaw oil so I took the tip and use chainsaw oil too.
It's about £3 for 500ml.
Seb
PostPosted: 00:55 - 12 Feb 2008    Post subject: Reply with quote
Profi dry lube seemed pretty decent during the nice weather towards the end of summer last year, but didn't seem to want to stay on the chain for any length of time once it started raining.
Yoshimoto gold wax seems to be the best wet lube I've tried so far, with it doing a good job on my current chain so far, fling isn't an issue like some of the white lubes I've used before and it even looks decent to boot Thumbs Up
2010 Triumph 1050 Sprint ST
Phoenix
Twisted Firestarter
PostPosted: 03:59 - 12 Feb 2008    Post subject: Reply with quote
Chainsaw oil is very good, it's sticky but runny enough to get inbetween all the links nicely, makes one hell of a mess of the back of the bike though.
Castrol chain wax really is crap, it just turns into this paste that attracts grit and crap and doesn't seem to have any lubrication properties whatsoever. I use Heine Gericke spray lube at the moment, it's a grease/oil rather than a wax but is gooey rather than runny and doesn't seem to flingoff much but keeps chain nice and loose, and doesn't cost a fortune.
Kiss_My_Rs
PostPosted: 05:15 - 12 Feb 2008    Post subject: Reply with quote
Http://www.manchesterbikers.net
kitty kat
PostPosted: 08:34 - 12 Feb 2008    Post subject: Reply with quote
As said earlier, engine oil Thumbs Up
gmanxiii
PostPosted: 10:08 - 12 Feb 2008    Post subject: Reply with quote
Fit a scottoiler
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
Cigaro
PostPosted: 10:23 - 12 Feb 2008    Post subject: Reply with quote
I use vegetable oil. That works fine and is biodegradable too.
Walloper
PostPosted: 10:41 - 12 Feb 2008    Post subject: Reply with quote
Dri lube is least messy. Side plates can get a bit rusty though.
Veg oil is not really best as you cannot control oxidation and it's load carrying stability is not great for the extremes a motorcycle chain can be subjected to.
But cheap... Unless you use that posh Italian Olive that comes in those dead fancy bottles.
UrbanRacer
PostPosted: 10:53 - 12 Feb 2008    Post subject: Reply with quote
Wurth Dry Chain Lube, make sure its the High Performance stuff
thegubner
PostPosted: 11:11 - 12 Feb 2008    Post subject: Reply with quote
Lubricant.
TheDonUK
PostPosted: 11:12 - 12 Feb 2008    Post subject: Reply with quote
I use Rock Oil Chain Lube
Nearly every mechanic i have watched uses it... That'l do me....
tristan
PostPosted: 11:33 - 12 Feb 2008    Post subject: Re: Reccomend me a chain lube... Reply with quote
Wurth everytime. I used Castrol wax stuff for a while too and didn't looked like someone had squirted toothpaste all over it. Laughing
LeeR
PostPosted: 13:15 - 12 Feb 2008    Post subject: Reply with quote
Asda 20W 50 motor oil 99p/Litre
My claim to fame: Austin Vince nicked my pen...
Walloper
PostPosted: 13:32 - 12 Feb 2008    Post subject: Reply with quote
My Arse!
I don't.
I have a Propeller Shaft.... Mr. Green
TheDonUK
PostPosted: 13:58 - 12 Feb 2008    Post subject: Reply with quote
Cant say i have ever watched a mechanic lubing a shafties walloper Wink
I have tried wurth dry wax but it went everywhere and my chain died in a couple of months...
Rock Oil FTW!
Walloper
PostPosted: 14:17 - 12 Feb 2008    Post subject: Reply with quote
Profi-Dri Lube. 16,000 miles and still puka. Goes on in 10 seconds every two-three tanks of fuel. Smile
Nada Mess. Thumbs Up
Itchy
PostPosted: 14:21 - 12 Feb 2008    Post subject: Reply with quote
Rock Oil FTW!
you do every 20,000 miles on the NTV you undo the bolt on the shaft and change the oil, same with some older BMWs which need this at 8000 miles.
TheDonUK
PostPosted: 17:24 - 12 Feb 2008    Post subject: Reply with quote
I knew someone would say it Smile
Maybe i should have been clear, 88% of the time i have seen a mechanic in a workshop or at home lube a Chain it was with Rock Oil Thumbs Up
How can anyone argue with such a strong piece of reserch?
Charlie
PostPosted: 20:11 - 12 Feb 2008    Post subject: Reply with quote
Gmanxiii wrote:
Fit a scottoiler
Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Fit one of them and get a gold DID chain, job sorted. You probably will only adjust it twice in 20,000 miles.
Walloper
PostPosted: 23:29 - 12 Feb 2008    Post subject: Reply with quote
Because it would not be bcf if we didn't..... Laughing
The last post was made 18 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 121.75 Kb
