Can't get this engine apart - pictures attached
joseph.griffin
PostPosted: 19:03 - 12 Feb 2008    Post subject: Can't get this engine apart - pictures attached Reply with quote
I have to design a 2 stroke engine very similar to this one (from a goped) for my uni course, so I'm taking it apart to see all the components. I'm stuck trying to take the flywheel/fan of the crank shaft because I can't see how it's fastened on. Have you seen anything like this before? How do I get it apart?
https://i232.photobucket.com/albums/ee145/josephgriffin/keyangky171001.jpg
https://i232.photobucket.com/albums/ee145/josephgriffin/keyangky171002.jpg
https://i232.photobucket.com/albums/ee145/josephgriffin/keyangky171006.jpg
https://i232.photobucket.com/albums/ee145/josephgriffin/keyangky171003.jpg
If anyone's interested, this is what the rest of the bits look like
https://i232.photobucket.com/albums/ee145/josephgriffin/keyangky171004.jpg
https://i232.photobucket.com/albums/ee145/josephgriffin/keyangky171005.jpg
https://i232.photobucket.com/albums/ee145/josephgriffin/keyangky171007.jpg
Joe
1999 Honda NSR125RX F Black and Silver (but with loads of scratches)
13/04/08 - Now a 1991 Honda VFR400R-M NC30 Black and Grey (Not road legal yet)
LeeR
PostPosted: 19:14 - 12 Feb 2008    Post subject: Reply with quote
Looks to me like it's a push-fit held in place by a piece of key-steel, have you tried pulling it off the shaft with a wide-leg bearing puller?
My claim to fame: Austin Vince nicked my pen...
finpos
PostPosted: 19:15 - 12 Feb 2008    Post subject: Reply with quote
It'll most likely be on a tapered shaft, so basically it's held on by a b*****d tight interference fit (I see you've got the nut off...). You'll need some sort of mechanical puller to get it off.
f.
CRAZY_BIKER
Guest
PostPosted: 19:20 - 12 Feb 2008    Post subject: Reply with quote
f.
Or heat.
NSR Mick
PostPosted: 19:23 - 12 Feb 2008    Post subject: Reply with quote
The shaft is quite possibly tapered and the flywheel seized on so quite a bit of hammer time could be in order.
joseph.griffin
PostPosted: 19:24 - 12 Feb 2008    Post subject: Reply with quote
What's one of those? I haven't tried - I don't have one. Can I bodge one from something else?
It does look like a key of some kind. On the top view, you can see something that looks like its holding it on, like a circlip. I tried wacking it with a hammer and punch but it wouldn't budge.
Joe
finpos
PostPosted: 19:34 - 12 Feb 2008    Post subject: Reply with quote
Look for "puller" on machinemart.co.uk, you can pick one up for a few quid.
You can do a bodge- put the big nut back on, find a big piece of steel you can bolt into the two big fat holes on the flywheel each side of the crankshaft so it goes over the nut, then undo the nut. You want the nut to push the big piece of steel upwards and that should pull the flywheel with it.
Heat might get it off, never tried.
The key will drop out when the flywheel comes off. It's not actually holding anything, it's only there to locate the flywheel.
f.
LeeR
Something like this, your uni will probably have one in the eng dept. or you could hire one from a tool hire shop.
cagiva gezzer
PostPosted: 20:03 - 12 Feb 2008    Post subject: Reply with quote
A puller along these lines:
https://i67.photobucket.com/albums/h294/supercitybity/Cagiva/Cagiva5-1.jpg
NSR Mick
PostPosted: 20:11 - 12 Feb 2008    Post subject: Reply with quote
How perfect of a length is that spanner. Thumbs Up
joseph.griffin
PostPosted: 20:48 - 12 Feb 2008    Post subject: Reply with quote
Got it apart...
https://i232.photobucket.com/albums/ee145/josephgriffin/keyangky171.jpg
I left it sitting in WD40 for a while, held it up by the flywheel and whacked the shaft with a big hammer. It was indeed a tapered shaft with a key (semi-circular key is in bottom right of picture)
Thanks for your help.
Joe
Pete.
PostPosted: 23:27 - 12 Feb 2008    Post subject: Reply with quote
I wonder how many thousands of crankshafts have been ruined by people doing that? The fine threads on the end of the shaft distort really easily making it impossible to re-fit the nut without some kind of remedial work. I've seen many ruined even when the nut has been fitted and used to protect the thread.
a.k.a 'Geri'
PostPosted: 23:28 - 12 Feb 2008    Post subject: Reply with quote
Just for your information, you probably knew anyway, but that type of fitting is properly called a "woodruffe key".
ZRX61
Victor Meldrew
PostPosted: 00:20 - 13 Feb 2008    Post subject: Reply with quote
"woodruff", no *e*
& as he didn't even know what a 3leg puller is & resorted to hammers to dismantle an engine I doubt he had the first fucking clue about woodruff keys...seems top have a firm grip on the principles of how to fuck up a crankshaft tho... Wink
bladerunner
PostPosted: 09:15 - 13 Feb 2008    Post subject: Reply with quote
Yikes hammered off the flywheel...broke the piston rings..and now your designing a motor. Steep learning curve I guess. Good luck
NSR Mick
PostPosted: 09:17 - 13 Feb 2008    Post subject: Reply with quote
I didnt see any mention of it having to go back together. Wink
ZRX61
Victor Meldrew
PostPosted: 15:18 - 13 Feb 2008    Post subject: Reply with quote
That's not the point. The guy evidently doesn't even have a basic grasp of mechanics, hand tools, strengths of materials etc.. & now he's supposed to design an engine??? LMFAO!!!
Eddie Hitler
PostPosted: 15:57 - 13 Feb 2008    Post subject: Reply with quote
Fuck off you annoying prick.
Shay HTFC
PostPosted: 16:15 - 13 Feb 2008    Post subject: Reply with quote
haha I almost spat out my tea. Its just the way it was so succinct and straight to the point! Laughing
ZRX61
Victor Meldrew
PostPosted: 20:55 - 13 Feb 2008    Post subject: Reply with quote
Was just wondering how on earth could anyone who calls themself Hitler have anything intelligent to say & he promptly proves the point perfectly Smile
Eddie Hitler
PostPosted: 21:04 - 13 Feb 2008    Post subject: Reply with quote
Wow, your quite a character. I take it your last point on the OP is intelligent?
Would love to hear your answer.
Damon
PostPosted: 21:37 - 13 Feb 2008    Post subject: Reply with quote
https://img513.imageshack.us/img513/4887/popcornvd3.gif
Damon
PostPosted: 21:38 - 13 Feb 2008    Post subject: Reply with quote
Eddie Hitler
PostPosted: 22:38 - 13 Feb 2008    Post subject: Reply with quote
Cracked.
Grav
PostPosted: 23:30 - 13 Feb 2008    Post subject: Reply with quote
All those who have not made a single mistake whilst learning about mechanics and engineering please take one step forward!
Dark Lord Of Custard
snigger..... Very Happy
The last post was made 18 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 127.01 Kb
