| scottishcammy |
 scottishcammy Nova Slayer
 Posted: 17:08 - 20 Feb 2008 Post subject: Please help with my carburettor problem. |
Ok , number one, I'm a shit mechanic, in fact, I'm no mechanic at all!!! biggrin.gif
I just got a Honda Varadero 125 and it started fine. However, the idle was a bit low (around 1100-1200rpm) and it would cut out.
I Tried to adjust the idle screw, but it was seized.
I broke out the big screwdriver and, like a right twat, broke it,
(see, told you I'm a shit mechanic).
Anyway, as the cable was broken, I turned (what I thought) were the 2 mixture screws on the carb a very small amount clockwise, around a quarter of a turn, to what seemed to be a closed position.
I've been trying for ages to start it and it won't start at all now!
I then noticed after a while a strong smell of fuel and I a large puddle under the bike (arrrggghhh!!!) which was coming from one of the pipes from the carb.
Now if I turn the screws eben slightly anti-clockwise, fuel pisses out the pipe, and either way the bike turns over but won't start.
I'm desperate to get out on the bike and really annoyed at myself that I've buggered it when it was starting fine before. s
Now I strongly need some advice pleeaassee! I'd love to get this sorted.
In the meantime, I've ordered a new cable from David Silver's.
Here's some pics. The screws I turned are the flat head screws, pretty much in the centre of the pics.
The broken idle screw is the one in my fingers.
Thanks in advance.
1. Broken idle screw cable:
https://i150.photobucket.com/albums/s85/scottishcammy/DSC00144.jpg
2. Screw on left side of carb:
https://i150.photobucket.com/albums/s85/scottishcammy/DSC00140.jpg
3. Screw on right side of carb:
https://i150.photobucket.com/albums/s85/scottishcammy/DSC00141.jpg
4. Pipe where all the fuel pissed out (what is all that white crap?!:
https://i150.photobucket.com/albums/s85/scottishcammy/DSC00143.jpg |
| Vincent |
 Vincent Banned
| Bru |
 Bru Trackday Trickster
| scottishcammy |
| Rowey |
 Rowey World Chat Champion
| Vincent |
 Vincent Banned
| scottishcammy |
 Posted: 18:19 - 20 Feb 2008 Post subject: |
Cheers! Far better to be honest
Ok, update, I switched the fuel tap to off, put the choke in, opened the throttle and turned the strarter motor several times.
It didn't start.
Then I opened the choke & fuel tap, throttle closed and turned the starter motor. Sounded a bit more hopeful, but still won't start.
ARRGGHH!!!
Any other ideas? Could I have done something breaking the idle cable?
Also, if the screws are drain screws, if I open them right up, will the excess fuel pour out, close them up and increase the chances of the bike starting, or have I not understood that correctly?
Thanks again, this is frustrating as feck! |
| scottishcammy |
 Posted: 19:20 - 20 Feb 2008 Post subject: |
| Grav |
 Grav World Chat Champion
 Posted: 19:50 - 20 Feb 2008 Post subject: |
They need a good scrub. Have you got a small wire brush, a set of feeler guages, a pair of pliers and a blow lamp?
Using the pliers, hold the plug in the flame of the blow lamp for around 20 seconds, this is enough time to burn most of the oily crap off and then you can use the wire brush to get the rest of it off. Make sure you have the correct gap on the electrode using your feeler guages and let it cool down for a few minutes before putting the plug back in. ____________________ Dark Lord Of Custard
snigger.....  |
| scottishcammy |
| Grav |
| scottishcammy |
| Rowey |
| Vincent |
 Vincent Banned
 Posted: 20:41 - 20 Feb 2008 Post subject: |
What plugs are they? CR8 EH-9  |
| scottishcammy |
| scottishcammy |
 Posted: 22:25 - 20 Feb 2008 Post subject: |
Not only am I a shit mechanic, I'm an impatient mechanic!
I cleaned the plugs as much as possible and put them back in.
Guess what, I got the bugger going!
Same as before though, engine ran fine, as long as I held the throttle open a wee bit. Even after 10 minutes warming up and the choke eventually closed, as soon as I let the throttle go right back, it would idle down to about 1000rpm and stall.
Very frustrating, but at least it started and ran (kind of ).
I'll just have to wait on that idle cable coming, then I'll see if I can muster up the courage to attempt to fit it (as I have NO idea). |
The last post was made 18 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
