Quick question..
st3v3
PostPosted: 19:09 - 21 Mar 2008    Post subject: Quick question.. Reply with quote
When a bike has a front ender and forks etc are mashed, how can you tell if the yolks/frame is ok?
Ichy
PostPosted: 19:16 - 21 Mar 2008    Post subject: Reply with quote
Unless there is physical damage, cracks, damaged paint etc it won't be easy.
I can only suggest measuring various features using the swingarm mounting point as a reference.
st3v3
PostPosted: 19:27 - 21 Mar 2008    Post subject: Reply with quote
Sorry, I meant Headstock, not yolks.
iooi
PostPosted: 19:32 - 21 Mar 2008    Post subject: Reply with quote
Would need to go an a jig at a guess to see if angles were still correct and maybe a xray?? machine to see if the metal had been overstressed or cracked.
Guess its cheaper just to get a new frame.
Whosthedaddy
PostPosted: 19:59 - 21 Mar 2008    Post subject: Reply with quote
Before you start slashing the cash on the shiny bits and bobs, get the frame checked over on a proper jig. If the frames cracked or warped and something happens as a result of it, it might not just be you that get hurt.
If its straight then its a more than reasonable repair job, if its knackered then it may save you wasting money.
The 7R was on a jig and straightened for not a lot of £.
How much does your piece of mind cost?
st3v3
PostPosted: 21:15 - 21 Mar 2008    Post subject: Reply with quote
Cheers fellas.
New frame not an option, this one get's fixed or I get a car, I've had enough. Piece of mind, obviously cheaper the better but I'm more than happy to pay to make sure it's 100% safe. Last thing I'd want is for something to happen and a kitten get's it.
How do I find out about a Jig/X-ray? How much am I looking at?
Whosthedaddy
PostPosted: 21:23 - 21 Mar 2008    Post subject: Reply with quote
Off the top of my head, the 7R for assessment and straightening was £165 maybe plus VAT. Got the receipts upstairs but really can't be arsed to go and look as naked birds on TV.
Dye and X-Ray, have no idea.
iooi
PostPosted: 21:30 - 21 Mar 2008    Post subject: Reply with quote
I would ask around some local dealers.
st3v3
PostPosted: 00:14 - 22 Mar 2008    Post subject: Reply with quote
Cheers, been more than helpful. Will dish Karma out when I can.
No worries WTD, I understand lol.
Whosthedaddy
PostPosted: 08:58 - 22 Mar 2008    Post subject: Reply with quote
I'm all tit and arsed out now so, where was I....?
The work was carried out by www.seastarsuperbikes.co.uk. They are in Norfolk and the bike was in Essex, so it travelled a fair distance to get done. Not sure about the accessibility of garages that can check frames near you, but you too may have to bung it in the back of a van or car.
I understand the bill:
Arrow Set up in jig to report damage £75
Arrow Labour £120 at £40/hour
Arrow Total including VAT £229.13
But have no idea about the work carried out?
18° short by 6°
9mm tight or maybe twist (my 4 year old has better hand writing than the mechanics)
23 1/2° straight.
Did not want to pull any more or I think headstock would have snapped off.
The price of the work may well be more than a new frame anyways and cause less problems in the future. Then again, the 7R has a tank sized frame compared to the BMX sized frame of the NS so the work and labour could be a lot less, or the damage caused in the front ender a lot more.
£75 would tell you either way, yay or nay to the frame.
A little piece of information on their website that may of some use to you:
We need your bike stripped of bodywork, with nuts, bolts and screws that hold the front yoke in the bike loose for fast removal of the front end of the bike. DO NOT remove the engine or swing arm (a stressed frame may spring further out of shape if these are removed), and we need them in to measure and more so to allow us to put pressure on the frame. In the case of practically all modern bikes, engines are a stressed member of the frame.
st3v3
PostPosted: 12:32 - 22 Mar 2008    Post subject: Reply with quote
Those measurements are nothing I would hope to understand.
I'm looking into the nearest place to have it done which may be Dewsbury (according to Google) and I think it's worth it tbh. I'd rather know it was safe than worry over every bump/pothole etc if it was 'time'.
Someone has mentioned some kind of plating though, welding a set of 'plate' bits over the welds of the headstock decreasing the stress on the headstock welds and putting it on the new bits of metal.
This is also an interesting and logical idea.
PostPosted: 12:37 - 22 Mar 2008    Post subject: Reply with quote
If you really want to do it then try:-
https://www.rapidbike.co.uk/
John Warrington is fairly local to York and has a good reputation.
A steel frame (like yours) is FAR easier to straighten than the alloy frames of most bikes.
st3v3
PostPosted: 16:03 - 22 Mar 2008    Post subject: Reply with quote
I'll do it as long as it's worth it.
I've checked the welds all around the headstock and they seem as was visually, checked around inside after removing yolks and can't see any cracks or anything. Would I be able to noticed anything that was hairline? I guess not....?
Thanks Keith, I'd also found a place in a unit type thing on the net this morning in Canary Wharf, Malton, same place? Will ring on Tuesday and check prices etc..
PostPosted: 16:58 - 22 Mar 2008    Post subject: Reply with quote
You might see paint cracked off on a bend, but sometimes not.
Being honest finacially it will not be worthwhile. The amount it wil cost you to get the NS checked and straight along with the other bits you will need it will be cheaper to buy another NS.
Ichy
PostPosted: 17:15 - 22 Mar 2008    Post subject: Reply with quote
I agree with Keith, the cost involved just doesn't seem worthwhile. I've frontended a few bikes in my time but never bothered checking the frame. You'll know the first time you ride it if there is something wrong. Guess its a personal thing?
You can check for cracks with food dye and chalk. Just cover the weld or whatever in dye, leave for a bit, wipe it all off then cover in chalk dust.
tutton
PostPosted: 17:18 - 22 Mar 2008    Post subject: Reply with quote
Pretty sure that needs ultra scanning
like they do with baby's
and all the parts which give sound back to the reciever are cracks.
Or thats what they do in car manafacturing
st3v3
PostPosted: 20:52 - 22 Mar 2008    Post subject: Reply with quote
The only reason I was considering the whole straightening thing was because I intend to do my test on it then get rid, I wouldn't want some young kid or kitten to have something bad relating to this going wrong for them. It seems logical to me if there was anything wrong, it would be visible outside or in, I've checked both and there's nothing different now to before. Agreed it's not particularly worth it spending all the cash, but I want it to be right, and better learning on this than some big bike that would cost twice as much.
Need new bearings now...... They're hard to find when small and fall out...
Thankies mucho for all the input. Karma (my PC won't let me rate for some reason at the mo but Ill sort it).
The last post was made 17 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 0.94 - MySQL Queries: 14 - Page Size: 98.04 Kb
