beatts |
beatts Renault 5 Driver
Posted: 21:04 - 24 Mar 2008 Post subject: Honda XR125 - Noise when Accelerating |
I have just bought a Honda XR125 L4 (54 plate) with 1200 miles on the clock.
I have a full license and have had big bikes but wanted a cheap reliable commuter.
The problem i have is when the bike is stationary and on tickover everything sounds fine, up the engine revs (still stationary) still sounds fine, but when I am on the bike accelerating it sounds like the bike is knocking or vibrating and very hard to pinpoint where it is coming from.
I stripped the bike down when I got it, to lube everything and check bolts for tightness etc and all seemed ok, the exhaust is the standard exhaust and is also nice and tight.
If I am riding with constant revs everything sounds ok, but when I whack the revs on (as much as poss on a 125!!) the noise returns.
There is no excess smoke, I changed the oil whcih wasn't too dirty, chain tension is ok (25mm ish) so I cant think what it might be.
The bike is very low mileage so you would hope nothing serious would be wrong with it this early on (he says doubtfully!), and the performance of the bike is exactly as I would expect - no probs at all.
any ideas anybody
It may be that this is normal for 125's but |
jackw72 |
jackw72 World Chat Champion
Posted: 22:19 - 24 Mar 2008 Post subject: |
I have the same bike, (for sale actually), if you could record the noise we could be a bit more helpful perhaps.
____________________ 08/11/2007 A2 Passed.
Suzuki GSXR 1000 K3
Rapid Training passed |
beatts |
jackw72 |
Posted: 22:26 - 24 Mar 2008 Post subject: |
How would you describe the noise?
Where are you based also, because someone near you might be able to help.
Suzuki GSXR 1000 K3
beatts |
MarkJ |
MarkJ World Chat Champion
beatts |
MarkJ |
Posted: 22:47 - 24 Mar 2008 Post subject: |
I have a Hornet 600, vid here --> https://www.youtube.com/watch?v=H0KhA0kbWJ8 although my 4 cylinder 600 will sound different to your single cylinder 125.
My recommended chain tension is 30-40mm, which is why I said 25mm seems to tight, although different bikes probably have different recommended chain tensions
eddclarke |
eddclarke Brolly Dolly
beatts |
MarkJ |
eddclarke |
beatts |
beatts |
Posted: 23:07 - 24 Mar 2008 Post subject: |
sorry as Eddclarke suggested not likely to be chain, I should read my posts before submitting them!! |
Noxious89123 |
Noxious89123 World Chat Champion
Posted: 23:14 - 24 Mar 2008 Post subject: |
I have a similar problem with my CBR. My chain is pretty much knackered, alot of the links have become extremely stiff and a few have seized completely.
When the chain goes over the front sprocket, it shapes itself to the front sprocket, but as it comes off, it wants to stay in a curved shape instead of straightening out. This causes the chain under the chain under the swing arm to bounce up and down.
Does your bike only do i at high RPM or high speed? Try it at a few different speeds then close the throttle and pull the clutch in and listen.
I get a kinda thumping sound, and the chain bounces back and forth against the rubber chain gaurd on the front of the swingarm.
It's not noticable when going really slow (under 10mph), and neither above about 35mph. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
beatts |
Noxious89123 |
eddclarke |
iooi |
iooi Super Spammer
Posted: 10:12 - 25 Mar 2008 Post subject: |
What are the wheel and sprocket carrier bearings like ? ____________________ Just because my bike was A DIVVY, does not mean i am...... |
Shay HTFC |
Shay HTFC World Chat Champion
beatts |
beatts |
MarkJ |
beatts |
iooi |
iooi Super Spammer
Posted: 22:16 - 25 Mar 2008 Post subject: |
If you can rock the wheel when its off the ground from side to side then you have bearing issues. Sprocket carrier you need to take wheel off and give it a good pull with your fingers. But to be honest if its only done the milage you say, they should be OK.
I would say that the chain need a real good lube up.
Maybe take it right off, clean it up and then give it a good soak with oil and hang for a while to let excess drip off.
Even better, but not sure if you can still get. Is the tins of chain greese that you put on a stove (camping one outside is best..) to melt. Once melted put chain in leave for a while then lift out. The grease gets inside all the joints, but because it then sets when cold does not get flung off everywhere. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
The last post was made 16 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
