ZX6R J2
mr.kris
PostPosted: 15:51 - 29 Feb 2008    Post subject: ZX6R J2 Reply with quote
hey i got a problem with my ZX6 its a 01 J2 i think it maybe gearbox related as i have only notised it in first and second however i cant be certen it seams to be a knocking evry few seconds however it dose not seam to get any worse faster or louder the faster or slower i go anyone got any ideas !
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
The Tot
PostPosted: 15:57 - 29 Feb 2008    Post subject: Reply with quote
Can you get a video of the problem? Can you isolate the noise source?
I'm thinking it "could" be the clutch? The plates maybe rattling in the baskets and maybe that's the noise you're getting. Does it jump out of gear when you rag it in first and 2nd?
The camchain should make more of a thonking sort of noise coming from the right hand side if it needs a new tensioner. It will rise and fall with revs so it's probably not that.
Look for smoke when you ride too as that may indicate valves/seals/piston rings.
We all know that kwaks all have rattly clutches!
Never argue with autism
mr.kris
PostPosted: 16:14 - 29 Feb 2008    Post subject: Reply with quote
cant get a vid as its only on the move but i just spoke to a mate who is a kwaka tech he said he will have a look on the 19th but he said maybe nothing to worry about but im sure u know what its like thanks he said clutch basket thust washer i just never had soemthing that didnt change with revs
TUBZ69
PostPosted: 17:15 - 29 Feb 2008    Post subject: Reply with quote
keep it in in neutral at a stand still an slowly pull the clutch in until u mite hear a rattly sound from the clutch area, if this is the sound ur hearing then its just the bearing (possibly thrust beaing, im no mechanic!) but is so its not alot to worry aobut
those who risk nothing, become nothing, achieve nothing....
c90 rvf 400, vfr 400, gpz 500, Gsxr 750, R1, Zx6r....
Louise
PostPosted: 21:45 - 25 Mar 2008    Post subject: Reply with quote
Instead of a new post ill add to this.
I have , I think the same problem.
Noticed couple of days ago its not sounding like it used to.
When revving theres a rattle, on the right side of the bike just under the tank - I think anyway.
Its not metal to metal more like something is loose.
When I pick up speed something below seems to 'run' faster and then 'slower' when I slow down. Didnt do it before
Also, if im in 1st/2nd and I hit a bump it will sometimes flick back into neatual and rev like mad.
Cam chain ?
Sparks is taking a look tommorow tho, but any other advice. Confused
The last post was made 17 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.97 - MySQL Queries: 14 - Page Size: 45.86 Kb
