Todays events and pics of the Gixxa (Prolly not 56k Friendly
Demonic69
The Pink Rhino
PostPosted: 18:16 - 09 Feb 2003    Post subject: Todays events and pics of the Gixxa (Prolly not 56k Friendly Reply with quote
Had a relatively productive day today.
Fitted my alarm (even got the indicators to work!), adjusted the clutch, adjusted the idle speed, tightened and lubed up the chain and went for a ride.
AAARRRGGGHH!!!!!
Bike won't go over 110mph. Gets to 100 in 5th then levels out at 10krmp. Power just gets really flat. Will go little quicker in 6th but then the powers on/off/on/off. Really don't know what's up Sad
Got some pics though:
Scooby
Scrappy Doo
PostPosted: 19:34 - 09 Feb 2003    Post subject: Reply with quote
If it's a Japanese import aren't they all restricted to 112mph? Confused
Doddmaster
PostPosted: 20:43 - 09 Feb 2003    Post subject: Reply with quote
Yeah there will be some sort of weird japanese restriction.
You will need to phone someone like Bat or BoxHill motorcycles and see if they tell you how it restricted. If not, take it back to Performance Motorcycles and tell em to derestrict it or you want your money back Twisted Evil
PostPosted: 21:20 - 09 Feb 2003    Post subject: Reply with quote
Yep, Japanese market bikes are often limited to 180kmh (112mph)
Not sure how the Gixer does it. Many bikes it is a sensor in the speedo, using a needle going past a light and sensor. Just bend the relevant needle and it works OK
Demonic69
The Pink Rhino
PostPosted: 23:31 - 09 Feb 2003    Post subject: Reply with quote
AAAAAAAAahhhhhhhhhhhhh!!!!! Not fun! The speedo only goes up to 180kph too Very Happy
Better get that sorted before I try to race Stewy!
I'll ring around tomorrow. Ta lads
Scooby
Scrappy Doo
PostPosted: 00:43 - 10 Feb 2003    Post subject: Reply with quote
Hence on 'try' Laughing
Demonic69
The Pink Rhino
PostPosted: 00:45 - 10 Feb 2003    Post subject: Reply with quote
You mean emphasis? Trying to find some info on how it's restricted (with the help of Stew and Goos) but still no luck Sad
Scooby
Scrappy Doo
PostPosted: 00:48 - 10 Feb 2003    Post subject: Reply with quote
It will be what Keith said, a sensor in the speedo.
Stew
If it's good enough for top race teams...
PostPosted: 00:49 - 10 Feb 2003    Post subject: Reply with quote
https://www.gixxer.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=5&t=000538&p=
Sounds like a CDI restriction.
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
Demonic69
The Pink Rhino
PostPosted: 00:50 - 10 Feb 2003    Post subject: Reply with quote
Can't be. I've got an in-line speedo converter so the bike actually thinks it's going slower
TiN
Pocket Tin
PostPosted: 00:53 - 10 Feb 2003    Post subject: Reply with quote
So the you're actually reading in MPH now? in that case, it can't be a sensor in the speedo (your reply might've been to Scooby's suggestion, but I'm reading your post after Stew's post), so something like the CDI sounds like the most probably cause...
TiN
dotgems.net
Scooby
Scrappy Doo
PostPosted: 02:00 - 10 Feb 2003    Post subject: Reply with quote
Yeah TiN, either that or he rides like a jessy Razz
Phoenix
Twisted Firestarter
PostPosted: 04:30 - 10 Feb 2003    Post subject: Reply with quote
what's with the pink tax disc holder? Confused
zaknafien
PostPosted: 07:36 - 10 Feb 2003    Post subject: Reply with quote
it's purple Shocked gay pride! Shocked Confused Shocked
knew you were hiding something dean Razz
02 Firestorm.
Demonic69
The Pink Rhino
PostPosted: 10:12 - 10 Feb 2003    Post subject: Reply with quote
Shut it Zak. I needed one ASAP and could only get a purple one. It'll be replaced by carbon fibre or silver soon enough.
My reply was to scooby, not Stewy Very Happy
I'm gonna give the dealers a call today and see if they have a clue how it's done.
Kris
PostPosted: 11:19 - 10 Feb 2003    Post subject: Reply with quote
You mean to say you actually buy tax?
www.prisonplanet.com
Demonic69
The Pink Rhino
PostPosted: 11:52 - 10 Feb 2003    Post subject: Reply with quote
I had to to get a reg plate. not intentional.
Called a few places and apparently I have to buy something that plugs in somewhere to remove the restriction.
More money!
But I was cheered up today.
D&K are selling a bike very similar to mine for £3000 Very Happy
Demonic69
The Pink Rhino
PostPosted: 17:16 - 10 Feb 2003    Post subject: Reply with quote
OK, think I've found something.
Apparently I can use an M-Max box or a Kiss Racing Delimiter to do the job. Very few people seem to have a clue though Very Happy
Any ideas where I can get one?
TiN
Pocket Tin
PostPosted: 17:26 - 10 Feb 2003    Post subject: Reply with quote
https://www.mitaka.co.za/accessories.html
It's in SA, but it's a start...
TiN
dotgems.net
PostPosted: 20:05 - 10 Feb 2003    Post subject: Reply with quote
If it is a cdi restriction then check whether you can just get hold of another cdi unit from a UK model (check the wiring is the same first!)
Maybe it is similar to some of the newer Suzukis and uses a gear position sensor, and from revs and gear it is triggering the limited. If so I suspect it can be bypassed with either cutting a wire or sticking a resistor into the wiring
Demonic69
The Pink Rhino
PostPosted: 21:41 - 10 Feb 2003    Post subject: Reply with quote
Yeah, I've been told I need to check the resistance in 2nd and then solder in a resistor.
Like I know how to do that!!
Everything's pointed to it being with the gears so far. Looking at about £60 for an M-Max box. I'll hopefully sort it next month
Stew
PostPosted: 22:27 - 10 Feb 2003    Post subject: Reply with quote
I guess an M-max box is something similar to this...
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=25623&item=2403064495
Unfortunatley the guy selling these items only seems able to supply de-restrictors for Honda bikes (RVF,VFR,CBR etc) and kawasaki ZXR400's.
Good luck on your hunt for speed, I want a fair race Razz
Btw, if you cant unleash the power of the Gixer M says she will race ya down the strip Twisted Evil
Demonic69
The Pink Rhino
PostPosted: 10:24 - 11 Feb 2003    Post subject: Reply with quote
Cheers mate. Tell her if she wants to race I'll remove the rev-booster and give it a go:D I've still got 118bhp up to 112mph though Wink
The last post was made 21 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.38 - MySQL Queries: 17 - Page Size: 122.08 Kb
