Setting up help required please
R6_Rider
PostPosted: 17:50 - 12 Apr 2008    Post subject: Setting up help required please Reply with quote
Hello all,
After having my 1991 Gsxf 750 for a month now I have just about got it all sorted. I have replaced all the fairings done a complete service on it and tidyed it up a bit. I am trying to get it ready for the mot in a few weeks but I need a hand get the carbs setup correctly. The bike starts fine but doesn't seem to idle very well and the choke sticks a bit so the bike revs around 2.5k all the time.
Would anyone who lives near be prepared to help me with getting it running in tip top condition?
Beer money etc would be avalible if someone could!
Thanks very much.
Simon
R6_Rider
PostPosted: 10:48 - 14 Apr 2008    Post subject: Reply with quote
I have checked the Idle screw and played with it but doesn't bring the revs down. It's like the choke is stuck on but with lever is moving ok on the carbs.
Anyone got any tips for me?
Cheers,
Si
Pie-Roe
PostPosted: 15:34 - 14 Apr 2008    Post subject: Reply with quote
Um, when you adjusted the rev screw was it warmed up?
What I did was find a nice long straight 60 road with next to noone on it.
Rode for 10 minutes, got to the end of this road, put bike on sidestand in neutral, fiddled with idle screw to reduce it, rode to the other end of the road. Repeat til the idle is correct. I don't know why, but you are supposed to use the full range of the throttle a couple of times while you are adjusting the idle.
If this doesn't help I'd see about (when cold) gently pushing the choke bar you can see on the carbs with it fully on and fully off, to see if theres any give there and if the choke cable is working or not.
Pyro
EDIT: Bollocks, just saw you are wanting it ready for mot. Well then get it warmed up so it doesnt need choke (ideally run it up and down your road?) then put it on sidestand and fiddle with the idle screw, then blip the throttle to just before redline a couple times, see how much it idles at now, then repeat 'til right.
R6_Rider
PostPosted: 06:56 - 16 Apr 2008    Post subject: Reply with quote
Thanks mate!
I will give that a go tonight and see how I get on with it.
Thanks again,
Si
The last post was made 18 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.91 - MySQL Queries: 14 - Page Size: 40.74 Kb
