CCM 644/ 710
richyqpr
PostPosted: 21:20 - 28 Apr 2008    Post subject: CCM 644/ 710 Reply with quote
hi everyone, i have just bought a ccm 644 with a 710 bore kit which is great.
But i used to have a yamaha yzf600r thundercat and the ccm is much slower? is this right?
I know the 600 is a sports bike but everyone says the supermotos r quick off the mark because they are so light?
Also am i hitting the rev limiter on the ccm because the gear ratio is closer together than the thundercat? because im used to the thundercat. it just sits at 1 speed reving high and then when i change gear it pulls like mad in the next gear?
It seems like i have to change gear well quickly?
Sorry for the essay but would appriciate a few answers.
Thanks
PostPosted: 23:01 - 28 Apr 2008    Post subject: Re: CCM 644/ 710 Reply with quote
Yes, it is right the CCM is much slower.
Not everyone says supermotos are quick off the mark because they are lighter - those that do don't really know what they're talking about.
The CCM will have a relatively more 'close ratio' gearbox because it will have a top speed in top gear of about 110 or something - as opposed to the 'cat being geared for 170 or so as stock, if I remember (obviously wouldn't quite get there). It also doesn't rev as high as the sports bike.
So yes, if you're used to a higher and wider revving sports bike, you may well get through gears quickly and hit the rev-limiter.
It should be noted that the CCM 644 is a quite slow and heavy example of a supermoto. Something like the Husaberg 650 could be up to 40-50kg lighter and make maybe 50% more power than the stock 644 - but pay the price in worse service intervals.
People may say supermotos are quick around twisty roads; which they can be, but I'd say it's still 98% in the rider.
The reason I to some degree like them and the reason others may consider them quick in twisty roads is actually the lack of power - you can make more use of what you have on a supermoto and not be doing ridiculous speeds.
The last post was made 18 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.55 - MySQL Queries: 14 - Page Size: 32.06 Kb
