Rounded Master Cylinder Screws
Thom
PostPosted: 09:38 - 31 May 2008    Post subject: Rounded Master Cylinder Screws Reply with quote
Any ideas for getting them out, they are completely rounded off and cutting a groove for a flat headed screw driver isnt an option or ill cut into the cap.
Also keeping in mind i dont have a drill bit small enough to drill them out...
Or any means of welding a nut to the top of them to extract them that way...
Finglonga
PostPosted: 10:13 - 31 May 2008    Post subject: Re: Rounded Master Cylinder Screws Reply with quote
Welding something to the top is a big no no as most of the brake fluid container is made of plastic (on most bikes) and brake fluid is more flammable that petrol.
May be you will have to get a new cap and screws and cut the groove in the top. Also buy yourself a decent screwdriver that fits them properly to avoid it happening again. Wink
Andy Sez....
F.Y.Y.F.F.
Ichy
PostPosted: 10:30 - 31 May 2008    Post subject: Reply with quote
Centre punch and a hammer will sort it. Like this but on the top face.
https://www.metacafe.com/watch/1144728/un_screw_you/
map
Mr Calendar
PostPosted: 10:39 - 31 May 2008    Post subject: Re: Rounded Master Cylinder Screws Reply with quote
Finglonga wrote:
...Also buy yourself a decent screwdriver that fits them properly to avoid it happening again. Wink
It doesn't help that the material used to make these screws turns into something like cheese over time.
I have this problem at the moment. Believe it or not replacement screws have to be ordered. I have them on order but will also try and source some stainless replacements.
Last time I got them out I used a gold/brass bit (like you get in the multi packs). DOn't know if it was actually softer than the normal ones but it did the job (thinking the screw bites into the bit rather than the other way round). Since sadly lent out the bits so looking for some more.
What thread post do you think you read to write a reply like that? Confused Rolling Eyes
The screws on master reservoir are counter sunk and IMO not enough space on the head for this to work. However, if you've done this on this type of screw rather than just watch a video I'll stand corrected.
Thom
PostPosted: 11:08 - 31 May 2008    Post subject: Reply with quote
I decided to be a typical guy and find my way around it. i back bled the system without even removing the cylinder cap. just alot of brake pumping and forcing of the syringe until it was all fluid and no air.
Seems to have worked.
Also, i didnt round the heads off im glad to say, the heads didnt exist when i bought the bike!
PostPosted: 11:47 - 31 May 2008    Post subject: Reply with quote
Just drill the heads off, not the whole screw out. You can easily undo the stump this leaves behind using mole grips.
Like this:
https://www.bikechatforums.com/files/master1.jpg
Phil_G
PostPosted: 11:54 - 31 May 2008    Post subject: Reply with quote
Like this:
Pressactly what I did.
+1 for this method Smile
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
carvell
Scuttler
PostPosted: 11:57 - 31 May 2008    Post subject: Reply with quote
S'what I did too.
Yamaha TDM 850
alains
PostPosted: 12:14 - 31 May 2008    Post subject: Reply with quote
if it's a NSR125R the cover is thin , the risk , when the heads are off that you wont have enough length to grip the screw . mark the center very acuratly the drill at diameter 3 , about 1/2" deep , then drill at diameter 5 to take off the heads . if you are able to take off the remains of screw , all ok otherwise drill at 3,2 mm then thread it again with a 4 thread 80 screw-tap .
i've done that 2 years ago . new screws countersinkscrew diameter 4 length 16 or 20 mm
the worst day fishing is better than the best day working
Odie
PostPosted: 13:40 - 31 May 2008    Post subject: Re: Rounded Master Cylinder Screws Reply with quote
[quote="Vincent"]
map wrote:
Best not to use SS ones, they'll react with the ally body, I've got annodised cap-heads on my Honda and have had no probs so far.Wink
Sorry but your rectum is talking, stainless steel is ok as long as you use some-thing like copper slip on the thread, anodised fasteners are the worst thing going, they fade and THEY DO corrode and weld themselves into the casings corrosion inhibitor or not (copperslip)!
I used to sell shit loads of heli-coil kits to idiots that had fitted anodised fasteners and had them snap when they were trying to undo them.
I have even seen a bike with anodised fasteners holding up the rear subframe of a bike, really clever (not)
As my learned brother stinkwheel stated, drill the head off Thumbs Up
You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat."
Thom
PostPosted: 15:53 - 31 May 2008    Post subject: Reply with quote
i got rid of my nsr recently Alains it's my GS500e that im working on.
I'll try the mole grip thing when i get some screws to replace them, thanks for the help guys!
alun111
PostPosted: 16:59 - 31 May 2008    Post subject: Reply with quote
my usual method is to either get the best fitting cross head screwdriver bit you can and try that - pressing as HARD downwards as you can, or try the best fitting flat head screwdriver bit!
It's absolutely essential that you put a LOT of pressure downwards.
Ichy
PostPosted: 17:41 - 31 May 2008    Post subject: Re: Rounded Master Cylinder Screws Reply with quote
Rolling Eyes I wonder why I bother sometimes. I obviously have an ability to do the impossible.
I've done it a thousand and one times on master cylinders and it always works. I couldn't be arsed to explain it and felt the video gave a good enough example for anyone with a basic mechanical aptitude.
Just for you I'll do my own video, on a master cylinder.
I even have a box full of counter sunk screws to replace the ones I've chewed up, cost just a few pence each and I've never had to order any.
A sequence of pictures showing my 16 year old son doing what I've explained after I chewed the screw up with an impact driver.
PostPosted: 18:48 - 31 May 2008    Post subject: Reply with quote
We're getting away from the main point which is that if people used the correct size screwdriver, the heads wouldn't be burred in the first place. They are never in THAT tight.
Mine was being drilled because it came not only pre-burred but had been hammered out with a punch then -wait for it- hammered back in again! Rolling Eyes
If anyone feels they are not capable of selecting the correct size and type of screwdriver, replace them with socket head screws instead.
I didn't even bother my arse using a countersunk screw to replace that one I removed. It's only holding the lid on against a big fat rubber gasket. As I recall, I replaced it with a cheese-head out of the bottom of my toolbox that was wider than the countersunk bit.
PostPosted: 21:03 - 31 May 2008    Post subject: Reply with quote
I hadn't realised how piss poor a lot of screwdrivers are until I got some good ones.
That said, a great many burred screw heads result from a phillips/pozidrive mismatch.
https://en.wikipedia.org/wiki/Pozidriv
69.9mph
PostPosted: 18:37 - 01 Jun 2008    Post subject: Re: Rounded Master Cylinder Screws Reply with quote
The hammer and centre punch is a legitimate method of countersunk screw removal, I've done it hundreds of times (also without the butchery to the adjacent casing as per the video).
There is one particular model of Leyland engine that uses loctited countersunk setscrews in the timing case, a real pig to remove. A bit of heat to decompose the loctite and some treatment from the centre puch was just the job. (I used to overhaul engines for a living).
Be careful when drilling out countersunk heads as the drill bit angle is usually different to the countersink angle, best to use a bit which is just slightly larger than the major diameter of the screw.
FlashBashly
PostPosted: 11:15 - 11 Jun 2008    Post subject: Reply with quote
I've just rounded one of mine off (cos I'm a complete numpty Rolling Eyes ).
Solution : Use one of the REALLY sharp screwdriver bits from a socket set and give it a right good hammering into the screw thread. Makes a nice bite into the soft metal then just screw out with the driver shaft.
Oh, and replace with a new cross head one Whistle
Flash
StealthDJ
PostPosted: 11:37 - 11 Jun 2008    Post subject: Reply with quote
If you're going to be brutal enough to use a hammer, then sod anything else, just use an impact driver. Much quicker.
Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
Previous notables: H100 S2 | CB250NA/B | CB250T | GT250X7 | Z650 B1 | SR650
Still owned, but long gone: RD250LC | CB750F2 SOHC | C50
There is a gap of 293 days between these two posts...
Quote Me Happy
PostPosted: 16:42 - 31 Mar 2009    Post subject: Reply with quote
Sorry to dig up an old-ish thread but it's better than starting a new one. I've just battled with the same problem and got the screw out and some nice new ones waiting to go in, but my question is, is it OK to use copperslip on the new screws to stop them seizing?
Seems like there's a couple of contradictory views in this thread.
PostPosted: 17:36 - 31 Mar 2009    Post subject: Reply with quote
I would (and do).
Although not actually sure how it works as I think the copper is meant to be less reactive by to trigger corrosion in other dissimilar metals that it is in contact with.
Grav
PostPosted: 19:44 - 31 Mar 2009    Post subject: Reply with quote
Copperslip is worth it's weight in gold and should be used wherever possible. I have never had any trouble with any fastener I have coated with it. It does not react with Alloy or Steel and keeps corrosion at bay. You dont need an awful lot, just a thin smear on the threads and as you tighten the fastener it will coat the threads evenly all round giving complete protection without fear of making the fastener loosen or stick like poop to a blanket. Thumbs Up
Dark Lord Of Custard
snigger..... Very Happy
The last post was made 17 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 140.37 Kb
