| darkangel |
 darkangel Nitrous Nuisance
| darkangel |
| NSR Mick |
 NSR Mick World Chat Champion
 Posted: 14:10 - 25 Jun 2008 Post subject: |
If it's cracked the cost involved in putting it right is likely to be more than the cost of replacement parts once you put the cost of getting them tested on top.
You could probably buy an engine for less than what testing and repairing is going to cost you.
Ebay Engine ____________________ If you dont like the way that I ride.......Stop trying to keep up!!! |
| darkangel |
| NSR Mick |
| sickpup |
 sickpup Old Timer
| darkangel |
| darkangel |
| darkangel |
| cestrian |
 cestrian World Chat Champion
| darkangel |
| Pete. |
 Pete. Super Spammer
 Posted: 18:07 - 25 Jun 2008 Post subject: |
If it's pressurising after a rebuild where it didn't before I would suspect what Sickpup says to be true. Ask the mechanic to check the base gasket.
The proper way to flatten the head/barrell is to lap it on a surface plate/lapping table. You can also use some fine grit wet & dry taped to a pane of glass ( I've used a double-glazing panel). Just rubbing it with wet & dry to clean it would be ok if you only used it to clean gasket residue. ____________________ a.k.a 'Geri'
| sickpup |
 sickpup Old Timer
| Aikman666 |
 Aikman666 World Chat Champion
 Posted: 18:46 - 25 Jun 2008 Post subject: |
Is there a temp guage on the thing to make sure that it isnt just plain overheating?  ____________________ Will work for petrol
My Design Blog |
| Pete. |
 Pete. Super Spammer
| sickpup |
 sickpup Old Timer
| darkangel |
| megastreak140 |
 megastreak140 L Plate Warrior
| sickpup |
 sickpup Old Timer
| darkangel |
| 2006 _p1 |
 2006 _p1 Crazy Courier
The last post was made 18 years, 76 days ago. Instead of replying here, would creating a new thread be more useful? |
