jmorgan |
jmorgan L Plate Warrior
Posted: 12:50 - 04 Jul 2008 Post subject: 1980 CX500 - Won't go above 55mph |
I purchased my first bike last night, an 1980 CX500 Custom. I think I made a very good deal, however the guy told me his father gave him the bike when he got too old to ride and ever since he had it the bike would not go above 55mph.
He says if you get on it, it will take off and go but when you hit 55 it "falls on its face", if you back off and ease up to it you can go over 55mph. The bike sounded fine, and didn't' hear any motor noise. I am not nearly as knowledgeable on bikes as i am cars but I really didn't' see how this could be anything engine related. I am just hoping its not one of those kind of parts that cost an arm and leg and a known issue with these bikes.
I did some google searches, and looking around and couldn't find any information about this problem. Maybe I am wording it incorrectly? I haven't driven it yet, so I can't say first hand what the problem is, I felt comfortable with the guy and got one heck of a deal on the bike. I'd like to think its something along the lines of something like a governor causing this issue, but honestly have no clue if this bike even has such a thing.
Any help is appreciated, I will be looking for a forum to call home now that I am getting into bikes! I have always wanted one, and well after a family crisis I finally decided to get one!
Kickstart |
Kickstart The Oracle
jmorgan |
Posted: 13:14 - 04 Jul 2008 Post subject: |
From what he told me its not rev related, its speed. I wont' know till I ride it which won't be sometime next week at the earliest. I decided to get a bike, and started watching and found this great deal so I loaded it in a pickup and brought it home. I still have to get a helmet, take the class, etc etc. I've ridden dirt bikes when I was younger and loved them, but I am sure this will handle quit different so I wont' take the course for both insurance, and safety reasons. I just couldn't turn down that I thought was a good deal!
The bike was purchased by his father, then gave to the son when he got too old to ride it. He tagged and drove it some last year then put it away for winter. The bike has about 42k miles on it. I am going to guess it has sat quite a bit.
Part of the reason I got a good deal was that he couldn't get it running for me. It would fire right up on starting fluid then die, he said gas sat in the tank all winter(could smell it), and his wife put it up for sale before he had time to get it running. I was comfortable with what I hear, when it ran off what he sprayed in the carbs that the motor was most likely ok. I also had a good feeling about the guy, apparently he had several dirt bikes, jet ski, a race car etc and his wife is making him sell most of it except the race car since thats all he does now.
I will be pulling the carbs off and cleaning them, I just wanted to get some ideas in case while I was doing the maintenance on it before I ride there was something else I should check/replace that is known to cause this issue.
I plan on getting it running next week, so any suggestions or things to check I will check then. Any comments, or suggestions welcomed:) I have been around bikes since my father owned a pawn shop and we got them in from time to time, however I have never owned one personally. |
Cigaro |
Cigaro World Chat Champion
hmmmnz |
hmmmnz Super Spammer
jmorgan |
Posted: 01:51 - 08 Jul 2008 Post subject: |
I got the thing running after cleaning the tank, replacing plugs and replacing fuel lines.
If you drive it, it is sluggish for what i'd expect.. I drove it in a circle for a while in case it broke down I wouldn't have far to walk. In first gear it is usually ok, however in 2nd it is getting to where it will just lose RPM and no matter how much throttle u give it, it just dies.
I messed with the idle screw, and I imagine i have it all kinds of screwed up now.. but it idles at about 1200-1500 rpm with choke in.. if you pull the choke the rpm doubles.
I noticed tonight that the right cylinder was warm to the touch, while I burnt the crap out of my hand on the left cylinder after lugging it around the parking lot a couple minutes. I pulled the plug, and confirmed it was getting fire. I pulled the air hose going to the air box off and it appeared the second cylinder started firing? I have the air filter out, but that screen is still in there(No clue how to get that out..
Also, if I put my hand over the inlet on the carb where the hose was, the rpms would go up and the engine sound would change.. |
Odie |
Odie World Chat Champion
jmorgan |
Kal |
Kal World Chat Champion
jmorgan |
Posted: 01:48 - 21 Jul 2008 Post subject: |
oddie is right it "could" be that stator, but im sure he will agree the symptoms of a stator can be the same as anything from a clogged air filter, bad plugs, bad wires, bad coil, bad connections, a short.
I've tested my stator's voltage and it appears correct(blue=100, white =90). At 2500rpm my battery is at the 14.x voltage. i'll finish checking the resistances tomorrow. The sad part is, everything can check out "correct" with the stator, and it still be faulty or dying.
I need to do the "white wire fix", as a test with a Y cable, but to be honest im afraid of what the results might be
I did notice today when I took it out, I was in 2nd gear and hit the 5k~ wall, I pulled the choke out and it kept on going up past 7k~rpm like no problem. This to me points at the carbs, or maybe thats just wishful thinking:) |
virus |
virus World Chat Champion
Posted: 08:50 - 21 Jul 2008 Post subject: |
Going purely on what you said about the choke, and the fact you've put a K+N on without putting bigger jets in, then Id think its running lean.
Time for more carb work.
John ____________________ own: 81 xs1100g...
Finglonga |
Finglonga World Chat Champion
jmorgan |
The last post was made 15 years, 282 days ago. Instead of replying here, would creating a new thread be more useful? |
