Greenychris |
Greenychris Nova Slayer
Posted: 16:17 - 01 Aug 2008 Post subject: Honda CB400 Clocks not working |
Hi.
I have a Honda cb400 super four 1992 and the speedo isn't working.
I have replaced the speedo drive as that wasn't working and the trip meter and mileage is now going up but the mph needle still isn't working
Does anyone have any advice on what the problem is or where I can get it fixed?
EDIT: Fixed
Only problem with the clocks now is when I turn the ignition on the temp gauge just goes straight up to the end at hot and stays there
Thanks in advance ____________________ Bike: Honda CB 400. Car: Pug 306 HDI.
'Car is for traveling somewhere in particular because you have to, Bike is for traveling nowhere in particular because you want to.' -skluff
RGE, Ride in peace.
mattsprattuk |
mattsprattuk Super Spammer
Posted: 22:02 - 01 Aug 2008 Post subject: |
if you shake the clocks, does the dial move? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
Greenychris |
Posted: 10:53 - 02 Aug 2008 Post subject: |
No they don't, every now and then I have to hit them to get the rev counter to work though. ____________________ Bike: Honda CB 400. Car: Pug 306 HDI.
RGE, Ride in peace. |
mattsprattuk |
Posted: 10:58 - 02 Aug 2008 Post subject: |
thats weird...
i'll use my amazing knowledge to tell you that something might be fucked inside.
new clocks is probably the way forward. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
Greenychris |
Posted: 11:21 - 02 Aug 2008 Post subject: |
Ok, is there any way to get them repaired as I can't find the clocks anywhere! ____________________ Bike: Honda CB 400. Car: Pug 306 HDI.
mattsprattuk |
Posted: 12:10 - 02 Aug 2008 Post subject: |
i dont know much about the innards of clocks. but i would think they are pretty precise, and not very user servicable.
i've got a broken set of CB400N clocks you can have if you want. they work, but would need a new screen and needle. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
Greenychris |
Posted: 12:20 - 03 Aug 2008 Post subject: |
Well thanks for the help Matt I managed to get the speedo working
The only problem now is the temp gauge goes straight up to hot and stays there all the time. ____________________ Bike: Honda CB 400. Car: Pug 306 HDI.
Greenychris |
Posted: 02:56 - 05 Aug 2008 Post subject: |
Bump ____________________ Bike: Honda CB 400. Car: Pug 306 HDI.
There is a gap of 10 years, 347 days between these two posts... |
SirFallalot |
SirFallalot Trackday Trickster
Posted: 22:04 - 16 Jul 2019 Post subject: |
Apologies for awakening a very old thread, but if you are still around.... (I have a 93/4 one)
I opened up my clocks because there were some loose plastic bits inside and the rear covers didn't hold.
The long plastic bit where the covers screwed in was broken, glued it back and happy days.
When putting things back together I turned the ignition on halfway through to check if I blew any of the bulbs, which caused a fuse to blow (stupid I know). Today I put a new fuse, so the dash lights work again, (xcept for the speedo one but might not be related).
ANYWAYS. as I passed my test this morning I took the bike today, and I don't think my speedo works right, it's very "vague". It doesn't go below ~10 mph, unless bike is off, and then seems to just slowly wander up or down slowly not sure if I can trust it, some bits I think it was about right, some I think I was doing 50 and it was showing like 40.
TL;DR
So, how did you get the speedo working??
Speedo converter was over tightened causing needle to be sluggish
Rev counter has recently stopped working intermittently. |
The last post was made 4 years, 285 days ago. Instead of replying here, would creating a new thread be more useful? |
