| Student |
 Student Renault 5 Driver
| ms51ves3 |
 ms51ves3 Super Spammer
| Student |
| ms51ves3 |
| Student |
| ms51ves3 |
| Wozza |
 Wozza Brolly Dolly
 Posted: 21:21 - 06 Aug 2008 Post subject: |
If the float bowl gasket was gone, air wouldn't be drawn in - fuel would be pissing out!
Get a Haynes manual, clean the carb, check/adjust float level, check inlet rubber for splits (if it's not between carb & engine, it'll be between airbox & carb), check fuel tap filter and sediment bowl and clean where necessary, rinse out tank (with petrol) if there's crap in it, check cap for airflow, check fuel pump adjustment, decoke exhaust. After that if you've still got problems, you might want to check inside the engine to see if you need new rings, a new piston or even a rebore. |
| Student |
 Posted: 21:37 - 06 Aug 2008 Post subject: |
I was told it was either the float or my oil pump adjustment that caused the grey smoke. all that happened when I looked at them is that I got to my current situation
The other thing I've looked at is air filter which was just completely replaced as it crumbled out of the vent
And the Carb is pissing fuel out :p Apparently as the fuel goes out it sucks air in, I don't quiet understand the logic but I still think the gasket needs to be replaced :p
P.S. And I have the Haynes manual for it. It just doesn't cover this problem, or if it does it's not easy to find
| ms51ves3 |
| Student |
 Posted: 07:55 - 10 Aug 2008 Post subject: |
Bike now makes lots and lots of noise
And gets from Point A to Point B making more noise
and goes bloody fast
So yeah my guess it works, just need to get it MOT'd and insured before so I can tax it (Well it's got no MOT everything else last til the end of the month)
So gonna look at my bank on the way to work and see what I can do for it's MOT
Thanks for all the help guys (And encase your wondering, it was the gasket in the carb above the float chamber, going to look at those other things if it packs in again any time soon) ____________________ Current bike/project - Suzuki GP 125
Wish bike - Suzuki Gladius |
The last post was made 18 years, 71 days ago. Instead of replying here, would creating a new thread be more useful? |
