| Ant132 |
 Ant132 World Chat Champion
 Posted: 11:50 - 10 Aug 2008 Post subject: Leaks.. |
Does anyone know of a decent 'stop leak' type fluid that i can use to temporarily stop a pretty decent leak ive got coming from my engine.
Its leaking gearbox oil, but will only leak when i have gone out and come back. It will not leak when the engine is off (not very fast anyway) or when it is idling. And as some of the leak was around the bottom of the gear lever oil seal, i suspected it and replaced it to find another small puddle of oil when i parked it up after a ride.
I think there may be a small crack in the crankcase.
Is there any type of 'gunk' or something that i can use to stop it or any type of fluid to add to the oil, until i have the time to take the engine out and repair it properly?
Can you use things like Radweld in there or is it strictly a no-go!?
Thanks, Ant  ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
| instigator |
 instigator Super Spammer
| tutton |
 tutton World Chat Champion
 Posted: 13:17 - 10 Aug 2008 Post subject: |
https://www.diynot.com/shop/Chemical_Metal_Tube/18658
Might also be worth trying to use some sealer before it.
Make sure its proper clean before using it to make sure it bonds properly too! ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
| Ant132 |
 Posted: 15:09 - 10 Aug 2008 Post subject: |
Nice one
Im gonna go get some and take the engine completely out to do i think.. Hopefully get a nice longlasting fix!
What type of sealer would you recommend? Ive tried some silicone before but it was no good.
| tutton |
| Ant132 |
 Posted: 15:48 - 10 Aug 2008 Post subject: |
| tutton wrote: | If your taking the casing off, clean thoroughly, whack the sealer on the inside of the rear, let it go off, then from the outside use the chemical metal and add a bit inside if you want, or just leave it as sealer either should be fine id of thought. |
Hi mate, what do you mean about the casing? And 'inside the rear' and 'outside'?
I was planning on taking the engine out, but not splitting it. Just using the stuff in your link to put on the bottom on the engine, where the crack is. Would this not work?
Ah, i know what you mean about the sealer now, ive got some stuff called 'blue hylomar', pretty sure its the same thing.
Sorry if im missing the point a bit
| tutton |
 Posted: 16:43 - 10 Aug 2008 Post subject: |
Just me im talking about as a general casing, so for you, sealer first let set then use chemical metal. Ye it would work doing it just like that, just me explaing it a bit funny  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
| Ant132 |
 Posted: 16:51 - 10 Aug 2008 Post subject: |
Ah right.. i thought i was just being a bit thick
Right, im gonna give it go tomorrow see how it goes.
Cheers for your help mate, Ant  ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
| ZRX61 |
 ZRX61 Victor Meldrew
| stinkwheel |
 Posted: 04:29 - 11 Aug 2008 Post subject: |
Of the chemical metals on the market, one called "JB weld" is probably one of the better ones.
I cannot emphasise enough how important it is to de-grease the area thoroughly first. Brake cleaner does an excellent job of de-greasing without leaving a residue.
That said, if you're taking the engine out, why not take it to someone who can do aluminium welding and get them to weld the crack up for you? This is assuming it is on a non-functional part of the crankcase ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Ant132 |
 Posted: 10:20 - 11 Aug 2008 Post subject: Re: Leaks.. |
| Ant132 |
 Posted: 12:11 - 11 Aug 2008 Post subject: |
Found the JB Weld stuff I can get it from ebay and various other sites but do you happen to know where i can it in person, to save having to wait for delivery and stuff?
Ive tried Halfords, Machine Mart and stuff..
Looks good though, some good reviews!  ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
| stinkwheel |
 Posted: 13:10 - 11 Aug 2008 Post subject: |
Almost anything can be welded if you have a sufficiently good welder.
There is a guy about 20 miles from me who I know for a fact has welded a new crown into a holed piston off a rare engine.
I've had big lumps welded back onto crankcases before and I've had an alloy "patch" welded over a 2" hole in the water pump cover on a bike following a crash.
I've only ever bought JB weld online.
Actual welding would be far better though, you just need to find someone who actually knows what they are doing. For that you will need to find out what's the word on the street Fuzzy Bear. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 18 years, 96 days ago. Instead of replying here, would creating a new thread be more useful? |
