Ye olde MOT question
GhostRider
PostPosted: 13:16 - 18 Aug 2008    Post subject: Ye olde MOT question Reply with quote
Afternoon all,
My MOT is up in early september. I think I should be fine on most things, got a dodgy right indicator that works on and off but I have narrowed this to a region of wire that must have a loose connection so will sort that out prior.
Other than that, the only thing I can think of is that the forks need new seals and bushes as the left one is leaking slightly. I am wondering if they check the chain and sprockets on an MOT, because I have a feeling they could do with being replaced, so would it be a good idea to say to them "Hi there, could you replace my fork seals/bushes/oil and chain/sprockets, then run 'er through an MOT?"
Im also weary of my rear brake pad, any concievable way I can put this to the test without having to fail the test first and thus fork out even more money that I dont have??
Cheers,
GhostRider
tzr
PostPosted: 09:25 - 19 Aug 2008    Post subject: Re: Ye olde MOT question Reply with quote
Not sure about the chain/sprockets, but about the fork seal: if you can't afford the work then what you can do it pull the dust-cover up and poke a ring of kitchen towel just below the seal and replace. It won't leak for the duration of the MOT.
prawny1
PostPosted: 09:39 - 19 Aug 2008    Post subject: Reply with quote
sneaky sneaky Razz
As long as the chain is adjusted correctly, and the teeth arn't badly worn and the chain doesn't pull to far back off the sprocket they should pass an mot
MaybeGuy
PostPosted: 10:23 - 19 Aug 2008    Post subject: Reply with quote
fork seals are only a failure if they leak onto other components.
Mr Hammers
PostPosted: 10:27 - 19 Aug 2008    Post subject: Reply with quote
...got a dodgy right indicator that works on and off
No, that's quite normal. All indicators do that.
A Guide To Powerbands
oriel dave
PostPosted: 12:37 - 19 Aug 2008    Post subject: Reply with quote
https://www.motuk.co.uk/manual/mc_contents.htm Wink
Europe Trip 2009
Rockhopper
PostPosted: 17:16 - 19 Aug 2008    Post subject: Reply with quote
Wrong!
https://www.motuk.co.uk/mcmanual_230.htm
GhostRider
PostPosted: 09:25 - 20 Aug 2008    Post subject: Reply with quote
All it is at the moment is that I can see oil residue at the top of the forks from where ive perhaps gone off a curb and thus compressed it, there is a small patch of oil around the rubber seal, but it is not at the stage where its leaking down the fork or onto the brakes or anything (I wouldnt ride it if that was the case) but im assuming its only going to get worse.
Lmao, walked into that one didnt I....
As far as the chain and spockets goes, I might try and get a picture up so that you can see how loose it is and the state of the spockets because you guys know what to look for way more than me, might as well show you the fork seals as well while im at it.
Cheers for the help so far guys, always appreciated!
GhostRider
The last post was made 17 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 14 - Page Size: 58.18 Kb
