| Carl Howell |
 Carl Howell Scooby Slapper
| stinkwheel |
| Carl Howell |
| Finglonga |
 Finglonga World Chat Champion
| stinkwheel |
 Posted: 10:00 - 22 Aug 2008 Post subject: |
Water really shouldn't be much of an issue on an inline 4.
I wonder if your HT leads are in poor condition or if they have been badly routed?
By badly routed I mean I've had a bike that had trouble in the wet and cured it by altering the position of the HT leads so they looped back from the coil then forwards to the plugs.
If the HT leads themselves look damaged or cracked, might be worth replacing them (assuming they are of the detachable type).
There is a product on the market called "Holts damp start" which is designed to spray over the coils and HT leads to prevent water ingress.
If water is pooling in the sparkplug recesses, check any drain holes aren't blocked, there is often a very small drain hole that comes out the side of the cylinder head. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Carl Howell |
The last post was made 17 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
