2001 r6 problem please help?
woda66
PostPosted: 18:52 - 18 Sep 2008    Post subject: 2001 r6 problem please help? Reply with quote
i have a 2001 r6,everytime i fire it up from cold (everytime) water comes from exhaust AND leaks from the link pipe connection to exhaust on the floor.its like a little puddle of water.im a bit worried its doing this everytime from cold when i fire it up.it goes away once the bike is warm etc... but dont quite know why its doing this all the time.ok maybe once or twice due to condensation etc.. but its everytime.it did not use to happen just started recently
your answers will be greatful
i heard it could be a head gasket problem
woda66
PostPosted: 19:26 - 18 Sep 2008    Post subject: Re: 2001 r6 problem please help? Reply with quote
tutton
PostPosted: 06:33 - 19 Sep 2008    Post subject: Reply with quote
Keep a eye on your coolant level, put a sticker on your expansion pipe of where it is, then check next day etc, if its going down its headgasket.
Davo
Davo To The Rescue!
PostPosted: 08:02 - 19 Sep 2008    Post subject: Reply with quote
If it is the head gasket, you could check the oil, it will turn milky white if water gets into it.
Failing that you can get a chemical that goes in to a sample of coolant which will change colour if combustion gasses are present, look for a coolant sniffer.
IIRC check to make sure it isn't water coming out of the overflow pipe as it's pretty close to the exhaust drain hole.
The last post was made 17 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 14 - Page Size: 39.63 Kb
