Twin light undertray for SRAD.
Davie_G71
PostPosted: 11:11 - 09 Oct 2008    Post subject: Twin light undertray for SRAD. Reply with quote
i'm looking at this on the bay:
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEBIDX:IT&item=120313015214
How hard are these to fit, as the standard under tray is one piece?
Cheers,
D.
Whosthedaddy
PostPosted: 11:20 - 09 Oct 2008    Post subject: Reply with quote
lllN30lll's old SRAD with a similar undertray but does look like its a one piece.
https://img.photobucket.com/albums/v707/lllN30lll/piccy-0032111.jpg
https://img.photobucket.com/albums/v707/lllN30lll/piccy-003221.jpg
Davie_G71
PostPosted: 11:22 - 09 Oct 2008    Post subject: Reply with quote
Aye, that one i posted looks like i'd need to cut the standard under tray.
D O G
PostPosted: 12:08 - 09 Oct 2008    Post subject: Reply with quote
Fitted a similar undertray to my SRAD.
You will need to cut the original undertray, effectively destroying it. It is made of frairly tough plastic too, so not as easy as it sounds. I went nuts with an angle grinder to get mine off in situ, a better (but much more time consuming) way to do it would be to remove the original, cut it down, refit and fit the new undertray.
Obviously you need to do some fairly low level electrics - cutting and crimping and whatnot. Furthermore, it doesn't look like that one has any provision for indicators, so you are going to need to create something - you lose the mounts when you chop the tray up.
The fit on mine was pretty poor, and it did need painting too, so was a lot of hassle really.
It looked good (well, it looked like every other SRAD with a shotgun rear end), but in hindsight I wish I hadn't done it. Non messed with SRADs are becoming rare now, if you have one leave well alone IMO. The rear end is actually quite attractive stock, and doesn't look chavvy either.
Davie_G71
PostPosted: 12:28 - 09 Oct 2008    Post subject: Reply with quote
You know, you're right. If anything i might stick a clear rear lens on it, but it looks good the way it is.
The last post was made 17 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 14 - Page Size: 43.45 Kb
