| frazer1981 |
 frazer1981 Nitrous Nuisance
| Kickstart |
 Kickstart The Oracle
| frazer1981 |
 Posted: 10:23 - 10 Oct 2008 Post subject: |
Wow that is a great help, as this has been a problem i never thought i'd get sorted... Thanks for the link bud
What would be the best set up for manily road use?(if the bike tops out @ 55-60 mph with a 15 front and 53 rear) I am looking for a gearing that would give me some more top end speed so i could ride @ 55- 60 with out thrashing the bike? was thinking smaller on the rear and maybe a few teeth bigger on the front ??? Any ideas? |
| Kickstart |
 Posted: 10:44 - 10 Oct 2008 Post subject: |
Well if it does 60 on the current gearing and would still pull the same revs then switching to a 45 tooth rear sprocket would make it do 70. That would be the same gearing ratio as the Honda MBX125 road bike.
Not sure there is the space to fit a much larger front sprocket (ie, almost certain you could fit a 16 tooth but a 17 tooth one I am less certsin about).
An possible alternative (found with a LOT of luck) would be to use the front sprocket from an MBX125 (JTF329, available in 12, 13, 14 & 16 tooth sizes) along with a JTR 243 rear (no idea what it is for, but 42 teeth and appears to have the same relevant mounting holes). Using 14:42 gearing with these would be the same ratio at 15:45 but would mean using a stronger 520 chain. Might be a clearance issue (but would doubt it) and the other issue is a small change in chain alignment (the 520 is about 1.5mm narrower and with the way Honda front sprockets mount it would offset the front sprocket slightly).
| stevo as b4 |
 Posted: 21:30 - 10 Oct 2008 Post subject: |
I would say it needs lower overall gearing than the MBX125, as it's taller and less aerodynamic. The MTX125's redline is 9000rpm, which is lower than the MBX. I would say to gear it for about 75-80mph at the redline, so that 60mph is around 7500rpm. That would probably be about right for a std full power bike, to get decent acceleration. You don't want to cruise a 125 trail bike much over 65-70mph, as it's not very comfortable sat up in the breeze.
A bit of experimentation might be needed to find the gearing compromise that suits you, the bike, and it's intended use the best. All i know is that on the KMX125 for example, going up 1tooth on the gearbox sprocket gives about 5-6mph more at the redline, so you won't want more than +2t on your front sprocket IMO, or alternatively, if you can get a 3-4tooth smaller rear sprocket for the same result. |
| Kickstart |
| frazer1981 |
The last post was made 18 years, 3 days ago. Instead of replying here, would creating a new thread be more useful? |
