suzuki burgman 125 accident
dizzykizzy
PostPosted: 17:00 - 12 Oct 2008    Post subject: suzuki burgman 125 accident Reply with quote
I had a slight accident a while back involving a transit van. Basically took the front end of the bike off. I am really keen to fix the bike but dont want to spend money until i know the engine is going to start. The ignition lights light up but the bike wont start. We have checked all the fuses but they seem fine. Plus we checked the battery. There is no damage to the engine so could this be anything to do with the starter motor or anything else?
Help would be good
Thanks
Cigaro
PostPosted: 17:05 - 12 Oct 2008    Post subject: Reply with quote
What do you mean 'won't start'? Do you mean the engine doesn't spin at all, or spins over but won't fire?
I'd check the ignition switch and the wires leading to it are OK first of all. Also the starter button itself. They are the most likely things to have been damaged.
Does it have an immobiliser? If not then try and bypass the ignition, there should be a schematic somewhere.
I've found a wiring diagram for the 400 burgman, but it's in German. Attached anyway if it's any help.
dizzykizzy
PostPosted: 17:57 - 12 Oct 2008    Post subject: Reply with quote
The starter doesn't spin at all and doesn't click. will check switches and see what happens.
cheers
The last post was made 18 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 14 - Page Size: 34.63 Kb
