CARBTUNE - permanent connection
stirlinggaz
PostPosted: 15:25 - 22 Oct 2008    Post subject: CARBTUNE - permanent connection Reply with quote
hi all,
at some point, the carbs on my project are gonna need balanced.
im planning on permanently connecting the 4 adaptors onto the bike.(with or without hoses)
these brass adaptors dont come with sealing caps, though im sure they used to.
& the hoses will be 3/16 id.
anyone any ideas how to seal the adaptors?
i suppose it would be easier to connect the adaptors & then shove on the hoses & seal the hoses up somehow but i'd prefer not to have the hoses permanately connected up.
any advice?
cheers,
GAZ
rotax81
PostPosted: 15:33 - 22 Oct 2008    Post subject: Reply with quote
a very short piece of hose with a ball bearing glued inside should do it.
just make sure the ball is big enough not to slip down the tube, although it is a very small tube.
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
stirlinggaz
PostPosted: 16:45 - 22 Oct 2008    Post subject: Reply with quote
hi,
good thinking.
just cut a couple of inches of hose for each adaptor, then glue in a slightly larger ball bearing to seal them up.
then, when needing to connect up the carbtune, just pull off the 4 short hoses & shove on the proper hoses.
excellent, now why didnt i think of that?
cheers,
GAZ
Finglonga
PostPosted: 17:15 - 22 Oct 2008    Post subject: Reply with quote
Used to use self tapping screws to seal the tube, no chance of the glue failing then. Wink
Andy Sez....
F.Y.Y.F.F.
rotax81
PostPosted: 17:45 - 22 Oct 2008    Post subject: Reply with quote
but more chance of an air leak Wink
even half an inch of pipe will do it, shorter the better.
you could screw and glue self tappers in there but i would go for something as light as possible as you dont want it pulling the pipe off.
go pull some pearl beads from your mums necklace, im sure she wont mind Wink
The last post was made 17 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 14 - Page Size: 45.23 Kb
