| Author |
| Syx |
 Syx World Chat Champion
 Posted: 15:09 - 22 Oct 2008 Post subject: Cylinder identification sensor |
I fear my CIS (03 R6) may be up the spout.
Questions: What exactly does it do, and how do I get a new one? Google is being very unhelpful.  |
| Back to top |
| 0ddball |
 0ddball World Chat Champion
| Back to top |
| Pete. |
 Pete. Super Spammer
 Posted: 18:28 - 22 Oct 2008 Post subject: |
I dunno how the r6 one works but Suzukis use a pin pressed into the camshaft, and a sensor on the valve cover picks up a signal from this pin so it knows when No1 is on a certain stroke. Sometimes (if the bike's been worked on/cams out) this pin gets knocked and the gap is wrong causing an error. ____________________ a.k.a 'Geri'
| Back to top |
| Syx |
| Back to top |
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 07:06 - 23 Oct 2008 Post subject: |
Check all of your fuses. Make sure there's no corrosion on any of them. It could be a voltage drop due to corrosion which could cause faulty readings from the sensors. When the bike is running the voltage is higher due to the alternator so it might overcome the corrosion. Check all your connectors too, ignition barrel for instance.  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| Back to top |
| Syx |
| Back to top |
The last post was made 18 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
