| T0MMY |
 T0MMY World Chat Champion
 Posted: 16:51 - 26 Oct 2008 Post subject: Wheel bearings |
I can feel and hear a little clonk from the back wheel of my CBR when I grab it at the top and bottom and give it a shake. First thought is obviously wheel bearings, the only thing is that it doesn't do it if you hold the wheel at each side (3 and 9 o'clock). Is that normal because I would have thought if there was play in the bearings it wouldn't matter whether you shake it top and bottom or side to side? The difference is that when I'm moving it top and bottom I'm putting a twisting force through the swinging arm bearings so is it possible it's these that are worn? I can't tell where the clonk is coming from even with my head up close so I'm not sure  |
| Kickstart |
 Kickstart The Oracle
| T0MMY |
 Posted: 17:52 - 26 Oct 2008 Post subject: |
This is being done on a centrestand (got to love CBR600Fs ). |
| stinkwheel |
 Posted: 18:32 - 26 Oct 2008 Post subject: |
You ought to be able to see a slight movement if it's the swingarm or suspension bushes.
Wheel bearings would normally "grumble" as you turn the wheel. Might be worth whipping the wheel off and having a feel of them. Remember there is usually one in the sprocket carrier too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| AJ |
 AJ Nitrous Nuisance
| T0MMY |
The last post was made 17 years, 110 days ago. Instead of replying here, would creating a new thread be more useful? |
