| click83 |
 click83 L Plate Warrior
 Posted: 17:57 - 29 Oct 2008 Post subject: Could you please help, bike won't start... |
I have a new piaggio zip 100 scooter but it fails to start my brother has an identical scooter with no problem.
Here my question, what is the arrow pointing at in the picture below ( the see-thru rubber cap ) because the one on my brothers scooter has some sort of fluid in it and the one on mjine has none at all.
https://i34.tinypic.com/nntbib.jpg
Could this be why my bike is not starting?
What is the arrow actually pointing at and as you can probably see, im new to the scooter larK
thanks. |
| rotax81 |
 rotax81 Nearly there...
| click83 |
 ---- World Chat Champion
 Posted: 18:25 - 29 Oct 2008 Post subject: |
That "plug" that the arrow's pointing at is so you can see if the airbox needs cleaned.
If the plug is missing on yours it could be sucking in too much air,which could stop it from running. ____________________ DRZ-400sm |
| G |
 G The Voice of Reason
| click83 |
 Posted: 18:56 - 29 Oct 2008 Post subject: |
Everything looks fine but that might just be because its me
More info...
When i try electric start i hear clicking noise as in its trying to start.
When i use the kickstart sometimes my lights flicker .ie. headlights - i nearly got it going but didn't keep the revs up long enough and it died on me again.
DAMN BIKE! |
| Davo |
 Davo Davo To The Rescue!
| Ariel Badger |
 Ariel Badger Super Spammer
| G |
| Ariel Badger |
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 14:04 - 30 Oct 2008 Post subject: |
Swap the number plate with your brothers bike then it becomes his problem....  |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
| Mick_Rs |
 Mick_Rs Derestricted Danger
| Odie |
 Odie World Chat Champion
| Cigaro |
 Cigaro World Chat Champion
| click83 |
 Posted: 16:56 - 30 Oct 2008 Post subject: |
Thanks for all the replies guys, really appreciate them.
Anyway, got my bike going after about 30 pain staking minutes of kick starting and took if for a good 30 - 40 mins run but when i turn off the engine it won't start when using electric starter only starts after another killer kick starting session.
Ann big reason why only a long kick starting is needed to get it going and electric start not? |
| Cigaro |
| click83 |
| Cigaro |
 Posted: 17:08 - 30 Oct 2008 Post subject: |
Yes, it should. Hence why I think you need a new battery
If the bike has been stored for a while without running then the battery can stop working. Or it could just be a bad batch.
To make doubly sure, connect it to a car with jump leads (make very sure you get them the right way round) and try it then. If it starts, the problem is in the battery.
As I said, what with the new ones being fuel injected, the engine will have a hard time firing if there's not enough power to run the FI system. Kickstart may be OK if the battery was only slightly dead. |
The last post was made 17 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
