Locating a rattle... diagnostic help... ?
Visitor Q
$25 whore
PostPosted: 18:28 - 06 Nov 2008    Post subject: Locating a rattle... diagnostic help... ? Reply with quote
Hi, basically my CBR 600 has developed a very loud rattle. If you can imagine bouncing on a trampoline with one spring very overstretched/too large for it, you're in the right area.
I don't know how long its been that way as I usually ride with music, but at most a week.
It doesn't seem to be affecting performance, but obviously I'm a bit concerned.
All the springs on the exhaust system /seem/ tight enough, which takes care of the obvious.
And although the chain clicks when you move the bike around, the rattle goes away when you pull the clutch in and seems rev dependent (not speed). Which makes me think its got to be /in/ the engine.
I replaced the camchain tensioner (CCT) about a year/5000k ago, so I don't think its that. But the bike could do with its valves doing, and I want to know if it is an evil portend.
Anyone got any experience of loud rev dependent rattles who could chuck some ideas in?
PostPosted: 18:32 - 06 Nov 2008    Post subject: Reply with quote
The rattle going away when you pull the clutch in suggests that it is a clutch / gearbox issue (assuming you mean iding, rather than riding along at 60 you can hear the rattle until you pull the clutch).
Visitor Q
$25 whore
PostPosted: 19:10 - 06 Nov 2008    Post subject: Reply with quote
It's the latter mate. It also kind of slowly fades too, which makes me think its vibration from the drive.
One thing that may be connected is the gear box selector has been very vague recently, with quite a few false neutrals (and this is straight after an oil/filter change).
Vincent wrote:
I've tried really hard but can't
No mis-spent youth for you then I take it (or high quality trampolines) Laughing. Ok, well as I was almost certain originally that it was a loose exhaust connector spring, that might give you an idea. It's one of those horrible rattles to describe, but a vaguely loose spring on something constantly vibrating is quite close.
Will have a go with the screw driver idea, but it doesn't seem as pronounced when idling. Only really seems a problem under load (ie moving... which could end up with some funny looks Wink Laughing)
Visitor Q
$25 whore
PostPosted: 23:03 - 16 Nov 2008    Post subject: Reply with quote
Christ. Page 5 within 10 days, Workshops got a turnover on it Laughing
Just a bit of extra info.
There is NO rattle for the first half a mile/five minutes. Completely quiet. Then it seems to be getting slowly louder as I go along.
The gearbox is still misbehaving regularly, although not necessarily at the same time as the rattle (or proportionately).
But it definitely sounds like its coming from the clutch/gearbox/possible generator area.
Thinking
I'm hoping it's just the CCT, but its failed very rapidly and sounds a lot more aggressive then when I last had issues.
I hope it's not the gear box :'(
Pete.
PostPosted: 19:52 - 17 Nov 2008    Post subject: Reply with quote
Sounds like a knackered chain to me. If you have the stretch specs for the chain measure it to see how far gone it is.
a.k.a 'Geri'
Visitor Q
$25 whore
PostPosted: 20:31 - 17 Nov 2008    Post subject: Reply with quote
Drive chain? The chain was fitted (with help from the lovely 'Vincent' off this forum - thanks again mate Thumbs Up) less then a year ago and has been lubed and tensioned regularly with no drama. I did check the chain tension and stretch to rule it out, and its totally ship shape.
Also the noise is coming from around the engine somewhere, and only when warm.. Thinking
Haven't got the money to just chuck it into a garage and hope they recognise the noise, but it may come to it. Bum.
Pete.
PostPosted: 20:38 - 17 Nov 2008    Post subject: Reply with quote
Could be a loosed or cracked exhaust header. If you are pulling in the clutch then you must also be shutting the throttle and reducing the load on the engine to almost nothing, stopping the noise. The noise a loose header makes sounds just like a mechanical rattle.
a.k.a 'Geri'
Visitor Q
$25 whore
PostPosted: 20:50 - 17 Nov 2008    Post subject: Reply with quote
Oooh now that sounds more helpful Thumbs Up
I have some horrible multipart blue flame headers (and pipes), and the spring for one side had heat fatigued and pinged off annoyingly. As it was loose and blowing I nicked one from the other side and wedged it on the loose side, stopping the blowing admirably and everything seems tight. I bought /a/ replacement exhaust spring, but I think it's too loose so didn't fit it.
I'll check to see if anything looks suspect that side.
As for reducing throttle with clutch in, I guess thats sound logic. I just did it to check it wasn't the chain/something loose but not reacting to engine vibes.
Why do you think it would only start the rattle when it's warm though?
It does continue after I've stopped and revved it at idle (after its started due to being warm) so it's possible, but the noise definitely /seems/ to be eminating from clutch/gearbox area Thinking
I hate diagnosing problems (although this beats an electrical fault anyday)
Pete.
PostPosted: 21:01 - 17 Nov 2008    Post subject: Reply with quote
Multi-part headers are supposed to be sealed with high temp/flue sealant to stop them leaking/wearing. Akropovik advise this. You can buy tubes of it from a plumbing shop. If you have a spring missing that will cause a leak/rattle many times and yes, heating up will very likely cause it to get worse.
a.k.a 'Geri'
Visitor Q
$25 whore
PostPosted: 22:26 - 17 Nov 2008    Post subject: Reply with quote
You star. I'm less happy about the joy of taking my exhaust of, but it might be less agro then the clutch/gearbox (by a high factor).
Have a cookie Thumbs Up
Well let you know how I get on.
The last post was made 17 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 80.64 Kb
