| rockers |
 rockers Scooby Slapper
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 17:22 - 05 Sep 2009 Post subject: |
hi,
when you had it running, did you leave it to idle for a bit?
this can foul plugs.
(best just not to idle it, but set off & keep it nice & slow till warmed up)
if its flooded & the bikes indoors, take the plug out, hit the starter a few times with the throttle wide open, & then leave it overnight.
any petrol left, should evaporate.
what plug are you using?
try a br9.
also, dont forget, that the battery, especially if its an old one, will flatten very quickly after a few attempts with the electric starter.
try bumping it into 2nd.
or charge the battery up overnight.
& then test for a spark.
if your getting a decent spark, move onto the carb.
is there fuel getting to the carb?
(open the drain screw for a second or 2, to see if fuel pisses out the bottom)
then onto cylinder.
have you tested the compression?
i'd be checking this properly, especially if its just been re-built.
who rebuilt it? which gasket was used?
cheers,
GAZ |
| Kickstart |
 Kickstart The Oracle
 Posted: 18:05 - 05 Sep 2009 Post subject: |
Draining the petrol from the engine is easy on the 123 engine. Under the engine, just in front of the starter motor there is a bolt (goes up pretty much vertically). This is there for locking the engine at top dead centre when setting the ignition timing but also makes a very convenient drain for the cases.
If you do try cranking the engine over with the plug out then make sure the kill switch is off (the AF1 will crank over with the kill switch off). Otherwise if the engine is full of petrol it will spray it out of the plug hole and the spark plug will likely ignite it.
I take it you are getting a spark? If the ignition timing is out then the engine may run but may well have problems. Unforunatly checking / setting the ignition timing requires a dial gauge and some faffing around.
If it is flooding that easily then it is probably well worth checking the carb settings carefully. Mainly the float height and the idle screw position. Could also be the needle valve, but that would have resulted in it flooding without the engine running so probably not that.
| rockers |
 Posted: 18:11 - 05 Sep 2009 Post subject: |
Hi cheers for the reply
i have got a decent spark
i didnt let it idle as such just rev'ed a little no much tho
am jumping off another battery so have loads of power.
fuel must be coming from the carb as before i got the bits to get it going i had taken the carb and reed valve off to clean and check them and looking into the engine it wasnt wet, but now am trying to start it there is fuel there its pretty wet.
compression- havnt got anything to test it but thumb over spark plug and theres alot of force back so should be good.
dont know who rebuilt the engine, i cant see round the edges the gasket looks to be green if that helps
its in the garage now spark plug out air filter off and no fuel line joined up.
my only thought is it is letting the fuel through willy nilly and flooding the engine being when i first tried to start the engine is had no fuel it and it started and died now theres fuel there in the engine (flooded maybe) it isnt starting |
| rockers |
 Posted: 18:14 - 05 Sep 2009 Post subject: |
posted before me
i set the timing vial topdead and backwards 1.8mm i think it is or19 degree |
| Kickstart |
 Posted: 18:26 - 05 Sep 2009 Post subject: |
| rockers |
| rockers |
| Kickstart |
| rockers |
| Kickstart |
 Posted: 16:41 - 06 Sep 2009 Post subject: |
The reed valves should seal against the reed block. If it doesn't then it can be a pain (had this with my YSR and it made it a pig to start).
The cable from the power valve is there so that when you press the back brake the power valve is opened. Idea is that around town it gets frequently opened to stop it sticking. Again shouldn't have much effect in stopping it starting, and it still has the spring to close it (or should).
Have you checked the jetting?
| rockers |
| Kickstart |
| rockers |
| Kickstart |
| rockers |
| rockers |
| rockers |
| Kickstart |
| rockers |
| Kickstart |
| rockers |
| rockers |
| Kickstart |
| rockers |
The last post was made 17 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
