| Dalemac |
 Dalemac World Chat Champion
 Posted: 01:34 - 23 Nov 2008 Post subject: Valves and rocker arms *edit* piston and valve location? |
Well....
i had the head and barrells skimmed by an engineering company which went to a professional motorcycle engine rebuilders.
i knew they would need to remove the valves, so gave them the head with valves still in, expecting them to remove them and give them back to me in labelled bags, so i could then relap them and ensure they are seated correctly, before putting them back in and putting the engine back together.
When i picked up the head, i didnt get told much, just that the head was only very slightly warped and that the valves had been removed and reinstalled. i presumed they had relaped the valves and inserted them in properly, considering the high price, and considering they went to a company dedicated to working on motorcycle engines.
so i put the bike back together, then when i come to the camshafts i notice that the rocker arms are not in the correct place to allow the camshafts to sit on the bearings properly, when they are correctly alligned for valve adjustment.
as you can see in the pics, the rocker arm is sitting on the valves correctly, but the valves are too high, pushing the rocker arms up and not allowing the camshafts to sit properly.
https://i9.photobucket.com/albums/a51/dalemckeown/Image112.jpg
https://i9.photobucket.com/albums/a51/dalemckeown/Image114.jpg
now i wouldnt mind but i wasnt told they hadnt been relapped and needed doing - otherwise i wouldnt have wasted the best part of a day rebuilding the head, checking everything and then checking again.
oso now i need to undo all the work i have just done, sort the valves out and them do everything again!
feels like im never going to get this bike sorted! ____________________
YBR125 -> GPZ500S -> SL1000
| sickpup |
 sickpup Old Timer
| Dalemac |
 Posted: 04:44 - 23 Nov 2008 Post subject: |
thanks for the reply sickpup, however the head is actually really clean, the camera just picks up little things. i have cleaned the whole thing inside and out before spraying with brake cleaner and re oiling everything.
the only thing i can think of is if the cam is supposed to be pushing down onthe valves at this point, but i dont enough about them to be sure....i mean will the exhaust valves for the left cylinder be open when the left piston is at the bottom of the bore?
thirdly i just watched blade - is the bloke in your avatar whistler?
______
edit: just found the following information:
| Quote: | 1.The piston starts at the top of the cylinder bore and descends. As it does, an inlet valve at the top of the cylinder (the cylinder head) opens to allow the air/fuel mixture into the cylinder. The descent of the piston creates a vaccuum effect that sucks the mixture in. This is the intake stroke.
2.The piston reaches the bottom of the bore. The inlet valve closes and the piston travels back up the bore, compressing the mixture trapped inside the cylinder. This is the compression stroke.
3.The piston reaches the highest point of its travel and the air/fuel mixture is at maximum compression. At this point a device on the roof of the cylinder creates a spark, which detonates the air/fuel mixture. The explosion pushes the piston back down the bore and ultimately drives the crankshaft (which the piston is connected to). This is the power stroke.
4.The piston reaches the bottom of the bore again. The cylinder is now full of waste gas left over from the explosion. This has to go. An exhaust valve at the top of the cylinder now opens and as the piston rises again it pushes the waste gas out through it. This is the exhaust stroke. |
so as i understand it, the right piston is at TDC, no valves for the right cylinder are open and if they were they would colide with the right piston. While the right piston is at the top, the left piston is at the bottom, so the exhaust valves are open. on the next stroke, the exhaust gasses are pushed from the left cylinder while the right cylinder is getting ready to push its own exhaust gasses from the cylinder.
On the next stroke, the left cylinder is compressing and then igniting while the right cylinder is expelling its waste gasses. etc etc.
so for every full rotation of the crank, the piston moves up and down the barrel twice.
thus meaning that when i come to put my camshafts back in, the right cylinder is doing nothing valve wise so the camshafts are located properly for the right cylinder, however the left cylinder is about to expel its exhaust gasses and therfore the exhaust valves are open.
so basically, as i understand it, i do infact need to bolt down the front camshaft because at this point the cam is supposed to be compressing the valve springs, opening the gap to the exhaust and getting ready to chuck the exhaust gasses through it.
If anyone can actually understand what i just typed, please tell me if i understand this correctly!
would explain why the front camshaft nearly jumped out of the engine when i removed the bearing caps.
Dale ____________________
YBR125 -> GPZ500S -> SL1000 |
| yandy_yay |
 yandy_yay Brolly Dolly
 Posted: 10:30 - 23 Nov 2008 Post subject: |
um, what he said
on a more serious note in a multi cylinder engine like yours there is always going to be 1 or more valves open, thus one or more rockers applying pressure to the camshaft, as sickpub says try tightening down the camshaft, i would do it slowly and evenly the bearing halfs should come together quite easily before to tighten to the specified torque. if the bearing halfs don't come together easilly enough i would take it off strip i down and start over... PITA but better to be sure than sorry.
Andy ____________________ past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s. |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Dalemac |
| NiteMare |
 NiteMare Spanner Monkey
| sickpup |
 sickpup Old Timer
| Pete. |
 Pete. Super Spammer
| Dalemac |
| NiteMare |
| Dalemac |
| sickpup |
 sickpup Old Timer
| NiteMare |
 Posted: 12:51 - 24 Nov 2008 Post subject: |
when setting cam timing.....
the crank has to be in a particular position, there will be timing marks on the end of the crank to indicate where...
then you set the cams in position in relation to the crank ...
now go back to your manual and check you have gone thru the whole process to set your cam/valve timing correctly ....
if you don't this repair could get very expensive
i've enquired about the cost of valves a couple of times due to cambelts snapping, had a citroen xsara snap the belt, 16 valve engine and 10 of them hit the pistons ...
Citroen wanted over £30 per valve , that would have been in excess of £300 without headgasket,oil and cambelt and then there would have been my labour on top (time to reassemble, cutting valves in etc) the total would have been way more than the value of the car....
i've no idea of the cost of your valves ____________________ it ain't broke...
i ain't fixed it enough |
| Kickstart |
 Kickstart The Oracle
| Dalemac |
| NiteMare |
| Ariel Badger |
 Ariel Badger Super Spammer
| Dalemac |
The last post was made 17 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
