| Thom |
 Thom World Chat Champion
| G |
 G The Voice of Reason
| MattEMulsion |
 MattEMulsion World Chat Champion
 Posted: 11:12 - 28 Nov 2008 Post subject: |
Why do you want to use something that is better than DOT4 anyway? DOT4 is fine for everyday use.  ____________________ Yamaha YZF-R6 |
| MarJay |
 MarJay But it's British!
| Cigaro |
 Cigaro World Chat Champion
| map |
 map Mr Calendar
 Posted: 11:43 - 28 Nov 2008 Post subject: |
As said, use DOT 4 if that's what it says on for the bike as that's what it was designed with. However, you can use DOT 5.1 (the .1 is important) if you've made any mods to the brake system or just want to try it.
DO NOT use DOT 5 on a road bike in everyday use.
I hope that's clear.
 ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Kickstart |
 Kickstart The Oracle
 Posted: 12:46 - 28 Nov 2008 Post subject: |
Dot 3, 4, 5 and 5.1 are road legal. From memory a load of Harleys use DOT 5 fluid.
DOT 5 is silicone based and cannot be mixed with the others (which are Polyalkylene Glycol Ether based). Also there is the possibility of seals in the system not being compatible with DOT 5.
Main difference is the boiling points.
DOT 3 = 205° C dry boiling point (140° C wet boiling point )
DOT 4 = 230° C dry boiling point (155° C wet boiling point )
DOT 5 = 260° C dry boiling point (180° C wet boiling point )
DOT 5.1 = 270° C dry boiling point (190.6° C wet boiling point )
A fluid might well only just meet one of these specs and massively exceed one of the others. For example fluids intended for race use might be rated DOT 3 as they have a poor wet boiling point despite a very good dry boiling point. For race use where they are expecting the fluid to be changed often the wet boiling point is pretty irrelevant.
The silicone based DOT 5 fluid is often said to give more level / pedal travel than the normal fluids (it is alleged the fluid itself is slightly compressible). Its massive advantage is that it doesn't absorb water and so should last pretty close to indefinatly (people lob it into rarely used classic cars so that they can ignore it, rather than DOT 3, 4 or 5.1 which would still need regular changing). The down side of it not absorbing water is that should any water get into the system it is very difficult to flush it out.
For a regularly used bike just put in a decent normal fluid (DOT 5.1) and change it occasionally. And unless you want to be changing the fluid every few weeks then ignore the specialised fluids for race use.
| Thom |
| Kickstart |
The last post was made 17 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
