No power at low revs on a ZZR1200
Slinn84
PostPosted: 13:33 - 24 Dec 2008    Post subject: No power at low revs on a ZZR1200 Reply with quote
This problem seems to be getting steadily worse. At first I dint notice it cos with all the ice been around I've not been too hard on the throttle.
After setting off in 1st with the revs around 3k I find that if i open the throttle up there's no power, the revs creep up slightly (though not in the way they would if the clutch were slipping), but the speed hardly changes, then a couple of seconds later, eveything kicks in. Its a similar situation in 2nd gear too. Once the power kicks in everything is fine and she flies like a jet but there just seems to be that flat spot.
Once christmas is over I'm gonna do all the usual checks (clean air filter and intakes, check throttle cable etc) but has anybody experienced this problem before, or does anybody have any ideas as to what might be causing this weak spot
Finglonga
PostPosted: 18:34 - 24 Dec 2008    Post subject: Reply with quote
Common problem apparently have a look on a few ZZR1200 forums and they will explain how to fix it. Most say the needle valves need shims to fix it completely.
Andy Sez....
F.Y.Y.F.F.
funmonkee
PostPosted: 00:24 - 27 Dec 2008    Post subject: Reply with quote
Easy fixes first Thumbs Up Add a little redex tothe fuel and check your plugs are good Thumbs Up
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
The last post was made 17 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.74 - MySQL Queries: 14 - Page Size: 35.89 Kb
