ripzay |
ripzay Nitrous Nuisance
Posted: 21:49 - 05 Jan 2009 Post subject: Suzuki GSXR400 starting problems |
Hi guys, i'm having issues with my '94 GK76A
The spark plugs are getting wet, so there is deffinitely fuel going to them.
I have tested the spark plugs and all four spark outside of the bore, but i'm having issues starting the engine..
once started it seems to idle and run fine. its getting to the point where i'm running the battery down before it will start now which is annoying.
i will get massive backfire through the exhaust sometimes when cranking too..
my questions:
1) to test my coils, what resistances should i see over the primary and secondary
2) with regards to the sparks themselves, how big / bright and what colour should they be ? at the moment they dont seem spectacularly strong, which is what's making me think the coils are bad.
also, of the two coils, the coil for cylinders 2 and 3 seems to get much warmer in use than the coil for cylinders 1 and 4
This might be a cold weather issue but i need to get it sorted as shortly this bike will become my only mode of transport for a while - i would buy a cheap 125 for my commute but i don't have the money at the moment.
Any help is greatly appreciated.
Thanks
Ben
P.S. i have posted this topic on 400greybike too but figured more coverage is best to get an answer - using the two heads are better than one logic ____________________ Current: 2005 KTM SuperDuke 990
Previous: 1996 Suzuki Bandit 600
Previous: 1994 Suzuki GSX-R 400 |
drew70 |
drew70 Trackday Trickster
Posted: 23:45 - 05 Jan 2009 Post subject: |
Speak to Stripes1976 on 400gb or www.gsxr400.com he helped me out loads a few years back when i had a 76a. Btw most probs with these bikes are carb related.
good luck |
Wafer_Thin_Ham |
Wafer_Thin_Ham Super Spammer
Posted: 08:44 - 06 Jan 2009 Post subject: |
I can only echo what Drew's said to be honest. Stripes is a good bloke, although I haven't heard from him in a while.
It could well be the O rings in the carbs have perished, are letting through stupid amounts of fuel and flooding the bike preventing it from starting. ____________________ My Flickr |
ripzay |
Wafer_Thin_Ham |
bladerunner |
Posted: 15:40 - 06 Jan 2009 Post subject: |
Well I think everyone has mentioned the O ring thing then!! As for how good a spark. it should be able to jump at least 8mm from the end of the HT lead to earth ie no cap. Nice fat blue one is ideal
And just to make sure have you tried fitting new plugs?Maybe a couple of them are on there way out. ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
ripzay |
Posted: 16:17 - 06 Jan 2009 Post subject: |
i have checked all four plugs and all for spark on their respective lead outside of the bores - i even got a shock a couple of times but i'm persistant!
i have tried with botht he old NGK standard plugs (cleaned and gapped correctly) as well as new NGK iridium plugs, both are as bad as eachother in terms of starting)
as for the choke working correctly, i presume so... once the bike is running it does what a choke should do - revs get higher as the bike warms up until i back the choke off at which point the drop
once the bike is warm with the choke fully off it idles at about 1100-1200, as set by the throttle adjustment under the carbs.
I've had the battery on a tender for the last few days to trickle charge it back up and i will pop down and try it again tonight, i'm hoping its just a low power issue causing the trouble and that a new battery will sort it.. i'll keep you updated.
i've never tried testing the spark with no cap / plug, is that a good idea? i presume the HT leads themselves have enough resistance to not burn out the coils testing this way ?
any other suggestions welcome! ____________________ Current: 2005 KTM SuperDuke 990
Thom |
Thom World Chat Champion
ripzay |
Thom |
ripzay |
Thom |
Cigaro |
Cigaro World Chat Champion
TUG |
TUG World Chat Champion
ripzay |
Posted: 00:10 - 08 Jan 2009 Post subject: |
Hi guys, quick update.. i'm stumped now.
i've checked all the spark plugs, all are DEFFINITELY sparking
now when i press the ignition the bike sounds like it's burning away the fuel where as before it sounded like it was just turning over
however it still wont catch, it sounds like it has caught every now and again, but doesnt stay running...
i'm starting to think it's a fueling issue but i suck at carbs, these ones particularly, i just dont know where any of the adjustment is apart from the idle air screw.
my battery was giving a constant 12.64 volts (and not dropping with the ignition turned on, so i dont have a leak to earth anywhere)
it stayed at just over 12 volts while turning over the engine but after half a minute of trying to start it had dropped to under 12 volts
and my battery tender said that it had half of its power left in it.. i'm thinking it might be a combination of a crap battery and bad carb setup
i'll hope it bump starts and buck it in at one of the local bike tuners for a carb setup and dyno run session i guess. i've had enough of it myself!
out of interest i took the top covers off a couple of the carbs to inspect the diaphragm, slider and needle conditions and all looked perfect to me.
one thing i havent done is taken the carbs off the engine and given them a clean but looking down the top of one with the slider + diaphragm out they look clean.
i drained all four carbs with the tank off, replaced the tank and turned if over a few times, the drained fuel was clean and free of particles, and the float bowls filled back up again after a few turns of the engine.
i'm at the end of my ability i think, time to call in the pro's. ____________________ Current: 2005 KTM SuperDuke 990
Thom |
Wafer_Thin_Ham |
Posted: 12:25 - 08 Jan 2009 Post subject: |
DO NOT USE EASY START.
It can snap the rods on the 76a. ____________________ My Flickr |
ripzay |
Posted: 20:43 - 08 Jan 2009 Post subject: |
well guys
I passed my Category A test today, but the bike still wouldnt start, guess i used up all my luck on the road!
i've taken the bike down to a friendly mechanic (runs the local bike club and is a friend of the family) he's going to jump straight to it tomorrow morning and hopefully have the thing running for next week..
Whats worse than having a bike waiting for you to pass your test...
having a bike and licence and still not being able to use them! ____________________ Current: 2005 KTM SuperDuke 990
bladerunner |
Pete. |
Pete. Super Spammer
Posted: 19:49 - 09 Jan 2009 Post subject: |
Same carbs as the bandit 400 I think. My sister's bandit was the same and I cured it completely by sorting the carbs. Main thing was in the bottom of the bowl there is a tiny jet set in the plastic housing that holds the float and each of them was blocked. That and setting the float heights made it start every time. ____________________ a.k.a 'Geri'
ripzay |
tractor664 |
tractor664 Derestricted Danger
ripzay |
ripzay |
Blau Zedong |
Blau Zedong Banned
The last post was made 15 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
