Removing camshafts TDC?
4Stroke
PostPosted: 20:08 - 26 Jan 2009    Post subject: Removing camshafts TDC? Reply with quote
Hi, been working on stripping down one my engines. Thought I'd pop over earlier as had a bit of time but didn't have my haynes.
removed the cams but then later at home was reading the haynes and it says to find TDC before removing cams.
I can't see why It should make too much difference until you come to install them. But reading that has got me worried.
Will it be ok?
Regards
NSR Mick
PostPosted: 20:19 - 26 Jan 2009    Post subject: Reply with quote
You will be fine as long as there is timing marks on the cams and the crank which is pretty much a cert.
PostPosted: 21:51 - 26 Jan 2009    Post subject: Reply with quote
It just means all the valves are closed and there is no load on any of the valvesprings pushing the rocker gear up as you unscrew it.
I usually rotate the engine so all the cam lobes are facing away from the followers rather than trying to find TDC.
Can't see as it would make a huge amount of difference in most cases in any rate.
The last post was made 17 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.01 - MySQL Queries: 14 - Page Size: 35.46 Kb
