Plating kits.
Ichy
PostPosted: 17:31 - 02 Feb 2009    Post subject: Plating kits. Reply with quote
Has anyone tried one of the DIY nickel plating kits?
I've a bike I'm restoring and its costing a fortune getting small parts done. I've seen the kits and wondered if they were actually good value for money? What are the results like? What about the cost of refills, anodes and salts?
Are there any other options, other than paint, that will give a good metallic, corrosion resistant finish? DIY passivation?
Cheaper the better. Thumbs Up
PostPosted: 18:10 - 02 Feb 2009    Post subject: Reply with quote
I have one of the kits, but not used it yey. Got most of what I need, but need something to store the chemicals in when not in use so looking for some cheap glass demi johns (sp?).
The anodes are not that cheap but should last a fair while.
Ichy
PostPosted: 18:20 - 02 Feb 2009    Post subject: Reply with quote
Hi Keith, any idea what kit you have?
PostPosted: 18:33 - 02 Feb 2009    Post subject: Reply with quote
Mine came from one of the Stafford shows last year from "Tec-Nick". I bought a larger kit that contains most things you need (then found my father had one of the smaller kits with pretty much just the basics in it, which he gave to me). Came with instructions, components to make the control unit (ie, box, bulb holders, wire and switches to use some 12V bulbs to control the "power"), chemicals, paper for testing the chemicals (presume it is litmus paper or something like that), electrodes, copper wires, thermometer, etc.
What I have sourced is a cheap fish tank for the plating and a long fish cooking dish to use to degrease things properly (there are some acid salts in the kit for this). As said I just need to source some large glass bottles to store the chemicals in when not in use.
NiteMare
PostPosted: 18:53 - 02 Feb 2009    Post subject: Reply with quote
Kickstart, ask on your local "freecycle" (yahoo groups) for your demijohns, that should give you a reasonably wide audience
it ain't broke...
i ain't fixed it enough
PostPosted: 19:01 - 02 Feb 2009    Post subject: Reply with quote
Good idea. Hadn't even considered that.
The last post was made 17 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.01 - MySQL Queries: 14 - Page Size: 50.45 Kb
