Shot my Wad
PostPosted: 01:06 - 02 Feb 2009    Post subject: Shot my Wad Reply with quote
Hi, there's a hole in my exhaust, it's underneath and near the end. About 20mm x 10mm.
It's not creating any backfires, but alot is escaping.
In a stab at the dark approach i stuffed a brillo-pad Smile in the hole.
It worked for abit.
What repair can i make? Something that doesn't invlove welding, and not an ugly bandage would be best.
Thanks
Pat
SoND
PostPosted: 01:25 - 02 Feb 2009    Post subject: Reply with quote
Is this your bike? You could try tapping the hole and sticking a bolt in it with epoxy but if it's rotted away in the first place it might be too weak.
https://www.motorcyclespecs.co.za/Gallery/Honda%20CB250RS%2082.jpg
PostPosted: 02:03 - 02 Feb 2009    Post subject: Reply with quote
Yep thats the bike, the hole has slight rusting and the chrome is thin, like the idea of resin n bolt..then again i might Shoot my bolt.
Just need a semi-perm fix until i can track down some replacements (don't want the motard 2-1)
Ta
Pat
PostPosted: 13:27 - 02 Feb 2009    Post subject: Re: Shot my Wad Reply with quote
Don't be picky. If you want a quick repair it's not going to be pretty.
A tin can and some jubilee clips Thumbs Up
LeeR
PostPosted: 20:54 - 02 Feb 2009    Post subject: Reply with quote
You could try a Holts Exhaust Repair Bandage or a Hermatite Exhaust Repair Bandage and a couple of jubilee clips to keep it in place.
My claim to fame: Austin Vince nicked my pen...
PostPosted: 21:50 - 02 Feb 2009    Post subject: Reply with quote
I'm such a vain sod, knew i'd give in to the jubilee or bandage.
Thanks for the sensible help
Pat
Robby
Dirty Old Man
PostPosted: 22:12 - 02 Feb 2009    Post subject: Reply with quote
Tin cans are a source of pre-bent metal. I have before now used some tin can, araldite, and jubilee clips.
However, I had the motad exhaust on my CB250RSA after the originals disintegrated. It's ok.
MandP used to do cheap parts of pattern originals, but this was 5 years ago.
PostPosted: 01:32 - 07 Feb 2009    Post subject: Reply with quote
I wonder if i could fit the silencers used on say the superdream or similar? Whats likely to happen when if i did ?
Really don't want a 2 into 1
Pat
BanditsHigh
Worse than a woman
PostPosted: 10:56 - 07 Feb 2009    Post subject: Reply with quote
Another method is exhaust putty, a metal plate and some pop rivets.
Make the plate big enough to overlap hole by about an inch and drill mounting holes in the plate. Position the plate over the hole and mark the first hole in your exhaust (to match up with plate hole) and drill it.
Next, exhaust putty over the silencer and a bit on the plate ... then pop rivet on, drilling and pop riveting the remaining holes.
Have fun Thumbs Up
The last post was made 17 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.8 - MySQL Queries: 14 - Page Size: 63.47 Kb
