TJ NSR |
TJ NSR World Chat Champion
craigT19 |
craigT19 Jolly Green Giant
Posted: 13:41 - 26 May 2003 Post subject: |
Also....
Don't use fully synthetic oil during the break in period, as it will effectively polish the inside of the engine, compromising the rings and bearings ability to hold oil. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
rallymad |
rallymad Renault 5 Driver
Korn |
Korn Admin
trigg |
trigg Derestricted Danger
Posted: 16:07 - 16 Oct 2003 Post subject: |
once it's been run in what oil should you use?
I have just brought a '94 nsr125 and the guy i brought it off said to use semi synthetic as well as a few mates but my local dealer said only use fully synthetic as semi could break down and cause the thing to seize!!!
I'm new to all this so any info would be a life saver.
trigg |
MarJay |
MarJay But it's British!
Posted: 16:10 - 16 Oct 2003 Post subject: |
Use fully synth, its the only way you'll get any peace of mind from a performance 2 stroke. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
cagiva gezzer |
cagiva gezzer World Chat Champion
trigg |
Posted: 18:29 - 17 Oct 2003 Post subject: |
thanks folks i'll fill up with fully synthetic next time it's empty.
only prob is it's just been filled up with semi so for the next couple of hundred miles i'll be waiting for a bang!!!! |
McJamweasel |
McJamweasel BCF Junkie
trigg |
Scotty |
Scotty Scooter Boi
McJamweasel |
trigg |
Posted: 19:37 - 19 Oct 2003 Post subject: |
cheers mate i was a bit worried for a bit it's a bit bloody anoying though.
I'd like to thank you all for helping me answer these questions i'm new to the biking scene and am thankfull for all the advice and support i can get.Nice one lads ____________________ i'd like to teach the world to sing...... |
bktan |
bktan L Plate Warrior
Scotty |
Scotty Scooter Boi
bktan |
baldrick |
baldrick Two Stroke Sniffer
baldrick |
bktan |
Posted: 01:57 - 28 Nov 2003 Post subject: |
baldrick wrote: | Just to clarify, the first post was really for 4 strokes only, the process of "running in" a 2 stroke is much quicker & simpler. A 2 stroke does not need any main or big end bearing run in period, it is the barrel & rings which requires the running in. This process is simply to warm the bike up to operating temperature & let it cool down 2 or 3 times. Then ride the bike not using the powerband for 50 miles, then gradually increase the revs by about 1000 every 50 miles. most 2 strokes will be run in by 250-350 miles.
My rs race bike runs in pretty much on the stand, then maybe a dozen laps. I use castrol a747, there are plenty of good oils on the market, motul 800t, silkolene pro, etc. |
i see, thanks for the info.
so using fully synthetic oil like castrol a747, motul800 and silkolene pro is ok? would they create too little friction for the barrel & rings to bed in properly to the cylinder wall?
and when u say runs in pretty much on the stand u mean u can pretty much run the bike in on a paddock stand and not ride around it? (e.g. no loading of the bike?)
btw any recommends for gear oil/trans oil during run in period as well? |
baldrick |
Posted: 00:33 - 29 Nov 2003 Post subject: oil |
Hiya,
I did not look to see whether A747 is synthetic or not, my choice to use that oil is based on it being the best for mixing with avgas, when I said RS race bike I did mean H.R.C. GP125. If you are running a road bike, simply buy what the manufacturer recommends or equivalent. As 2 strokes burn the oil off every "2 strokes" & do not run shell bearings, the qualities of the oil needed are quite different & do not always relate to what a 4 stroke needs.
Yes, I do mean I can almost run the bike in on the stand, but as I have stated, I do about a dozen laps, bringing up the revs & the throttle opening, until the last lap I do is full chat.
I only use one oil for gearbox, running in or racing, silkolene light gear oil, but again, use what the manufacturer recommends & you will not go wrong. |
The last post was made 20 years, 182 days ago. Instead of replying here, would creating a new thread be more useful? |
